Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 12-02-2006, 14:05
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
Bumper Clearence on the ramp
Is anyone having the problem i am having of trying to design a bumper that will be high enough to let the robot go up the ramp?? We had one design but only to be told it was against the rules.
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
Unread 12-02-2006, 14:33
tjanson tjanson is offline
None #1768
tjanson is an unknown quantity at this point
Re: Bumper Clearence on the ramp
It's called lots of torque and 4 wheel drive. Mmmmm.
Sorry for not making a worthwhile contribution.
Unread 12-02-2006, 14:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
who says you need bumpers?
Unread 12-02-2006, 15:06
ctshirk7's Avatar
ctshirk7 ctshirk7 is offline
Curtis Shirk
AKA: Curtis Shirk
FRC #1108 (Panther Robotics)
Team Role: Student
ctshirk7 is on a distinguished road
Send a message via AIM to ctshirk7 Send a message via MSN to ctshirk7 Send a message via Yahoo to ctshirk7
we were havin a hard time and then we discovered eye bolts... they work quite nicely... eye bolts that are long enough that you can mount the bumper high and its easy to remove... you might like to use it...
Curtis Shirk-Panther Robotics 1108
Unread 12-02-2006, 15:14
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Remember, you cannot possibly get everything you want in FIRST. If you want to get up the ramp, you may have to give up on having bumpers on the ends of your robot. If you want bumpers on the ends of your robot, you may not have enough clearance to get up the ramp. It is all about compromise and what your team views as the higher priority.
And if you are mad about this, the bumper rule was purposely designed this way.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-02-2006, 16:19
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
To work within the bumper rules, we're only able to have bumpers on the corners of the robot. We need close to 4.5" of clearance in the center of our wheelbase, which doesn't allow for the placement of bumpers.
However, we're only losing a 15" or so wide span of bumpers on the side of the robot. That still ensures that most robot-to-robot contact will be against our bumper, and not a direct hit to the frame. I'm mostly worried about the front of our robot, which will not have any bumpers at all (due to the ball collection device.) A direct hit in this area is sure to do some damage, as the corner of a low robot can get under our frame and into some pretty important parts. (Don't worry, we're not mounting electronics there...)
Bumpers this year are a blessing and a bother. Use them where you can and just be happy that you don't have to fit them into your 120 lbs.
Unread 12-02-2006, 16:23
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
what rule did they tell you that design was against?
Blargha!
Unread 12-02-2006, 16:44
Bengineer
Rule <R35> specifically. And, the following responses, among many, on the Q&A forum. As these are the only official answers, I won't link to any of the discussions from here on CD...
Q&A 1
Q&A 2
Q&A 3
And so forth...
BEN
Unread 13-02-2006, 15:10
AKA: Escue
we were planning on using hinges so whenever the front hit the ramp the bumper would have moved out of the way.....i have about 3 bumpers built and they seem like they will work if i can attach them easily and get them off easily....how exactly are you using the eye bolts???
Unread 13-02-2006, 15:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Careful on your hinges idea. There have been a couple of recent Q&As that state that bumpers must remain in the same vertical orientation they started in, throughout the match. That's relative to the robot, of course, but it means you can't hinge the tops of your bumpers so they'll flip up slightly out of the way when you hit the ramp.
I suspect your only option for using a full set of bumpers this year is to have a 6-wheel drive chassis or something that gets your effective wheelbase as small as possible
Unread 13-02-2006, 16:41
AKA: Escue
Ya we completely scrapped the hinge idea saturday and we thought we had another way of attaching using 80-20 but the 80-20 will extend too far out so im gonna try to look into the eye bolt idea, if i can find the right size ones
Ramp and Tipping Nitroxextreme Rules/Strategy 10 10-02-2006 15:01
Ramp Scoring, At 00:00 or After? Rombus Rules/Strategy 21 05-02-2006 17:02
bumper customization? gondorf General Forum 20 01-02-2006 19:30
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Bumpers & the Ramp Gary Bonner Rules/Strategy 2 26-01-2006 11:13
