Go to Post Michigan is all about tough love. If you can make it there you can make it anywhere. - Koko Ed [more]
Unread 12-02-2006, 14:15
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
Important question regarding starting position of balls in the BOT
hey guys, my build team just posed a tricky question, which im almost 100% sure the answer is positive
the question is wether or not balls are allowed at the start of the match (we are speaking of the 10 autonemous balls) to be under pressure, what I mean is
we have a conveyer belt to push the balls up our bot from the floor, the coveyer belt puts the balls under a very strong amount of pressure so they will go up easily, are we allowed to put the balls in that stress-position before the start of match?
also on the same question, can we put balls on the floor beneath our bot?
thank you very much.
We cannot enter into alliances until we are acquainted with the designs of our neighbors.
- Sun Tzu
I guess someone should tell Mr. Tzu about FIRST
check out our HERBEW translation to the 2006 game manual at: http://www.avivrobotics.net
Don't mess with Nimrod's
Unread 12-02-2006, 16:22
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Important question regarding starting position of balls in the BOT
You are allowed to put balls anywhere in your robot before the match. I'm not sure if you're allowed to power up to do so though, so you might need to design your conveyor belt so the balls can be inserted and put under pressure by hand.
The floor underneath your robot would not be considered on your robot, so that would be a no.
Unread 12-02-2006, 17:17
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Also, and I'm sure you're aware of this, but all balls must be easily visible. If you are allowed to keep balls underneath your robot, they must be seen.
Hi!
pic: Cyber Blue 234 Starting Position CD47-Bot Robot Showcase 7 03-03-2004 21:50
Starting Position question Ben Mitchell Rules/Strategy 5 11-01-2003 20:28
Starting position? Mark Garver General Forum 4 06-01-2003 07:45
Important Issue! archiver 2000 7 23-06-2002 22:37
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
