Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 12-02-2006, 20:02
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Your animation will NOT be judged...
Your animation will NOT be judged if you didn't read the rules and submit it in an acceptable format.
I have been perusing several of the animations that have already been sent to Streamline. Of the 51 animations I looked through, 24 of them - practically half of the entries - use illegal codecs, have improper image size, exceed the file size, or exceed the time limitations. Half of the entries are not in compliance with the submission requirements and are probably going to be disqualified by Autodesk. Based on past practice and what we have heard from Autodesk, they will be absolutely ruthless this year in ensuring compliance with the submission rules.
To have half of the entries submitted not even make it into the judged portion of the competition, just because the animation teams didn't bother to take the simple steps involved with reading the rules and submitting in a proper format, is tragic. Some otherwise fine animations are going to be completely ignored because someone on the team made a stupid little mistake like using a MPEG-4, animation, Sorensen 3, or H.264 codec instead of the required DV-NTSC codec. Or they sent in an animation with a 640x480 frame size, which is explicitly prohibited. Or they submitted an animation with a file size of 700+MB, when rules limit file size to 250MB.
If you don't want your five weeks of very hard work to be completely wasted, PLEASE PLEASE PLEASE make sure that you understand the submission requirements and send in a legal animation! There is still time to re-encode your animations and re-submit them to Streamline before the deadline.
-dave
Unread 12-02-2006, 20:05
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
Re: You animation will NOT be judged...
i'm not sure which ones you looked at, but is it possible, that team 1312's is not good?
Unread 12-02-2006, 20:16
dlavery's Avatar
Curmudgeon
I don't have the full list in front of me right now. But you should be able to check your animation file directly to ensure compliance. Since all submissions have to be Quicktime moves (NOT .avi files!!!), use the Quicktime Player to display the movie. Do a "get info" on the movie, and see what codec, image size, and frame rate show up in the info window.
The best advice that I can give to every team is, once you have uploaded your animation, immediately download it again from Streamline and make sure that the version stored there is complete and readable. There are a number of uploads that have a file size of "0" indicating that the upload did not complete, but the teams never bothered to check their submissions and correct the problem.
-dave
Unread 12-02-2006, 21:15
animator1's Avatar
Animator
Team Role: Animator
ok, thanks for this reminder and help tip. I rechecked and everything is ok. Can't wait to see everyone else's animations.
Unread 12-02-2006, 21:57
Tyr's Avatar
Tyr Tyr is offline
AKA: Colin Windmuller
FRC #1086 (Pirates of the Black Pearl)
Team Role: Animator
Tyr is an unknown quantity at this point
Can you have a still image on the 5-second slate?
Just because I can't spell it
doesn't mean it didn't happen.
Unread 12-02-2006, 22:00
animator1's Avatar
Animator
Team Role: Animator
yes, i know i do, and i have seen many teams have it. especially in past years too.
Unread 12-02-2006, 22:04
Tyr's Avatar
Tyr Tyr is offline
Team Role: Animator
thanx
Unread 12-02-2006, 22:17
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
How can I check the dB of the audio? I have no idea how.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 12-02-2006, 22:30
animator1's Avatar
Animator
Team Role: Animator
it depends on what program you are using. it should say with the audio settings in the editing program you are using.
Unread 15-02-2006, 18:54
DinkyDogg DinkyDogg is offline
DinkyDogg is an unknown quantity at this point
I just realized that our animation is 30 fps, rather than 29.97. It's DV-NTSC, and seems to fit all the other requirements. Is this liable to be a big deal, and is it too late to fix it?
I'm a bit worried.
Unread 15-02-2006, 21:31
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Honestly I don't really know why they use such an odd req framerate, I like 25, because it leaves it very easy to calc time with frames but with 30 and 29.97 it is a pain in the... er rump. Anyone know why 29.97?
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 15-02-2006, 22:49
Happy Birthday! steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
29.97 is NTSC standard. More info here: http://en.wikipedia.org/wiki/NTSC
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 15-02-2006, 23:04
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
in short, it has to do with the fact that our wall outlets (AC power) operate at 60hz, or 60 cycles per second. That means all lights using an AC power source are flickering at that rate, which is too fast and too subtle to be seen. if the framerate (and thus the screen refresh rate) is exactly 30, it essentially produces a visible harmonic flickering, which is often disturbing and uncomfortable to watch. In Europe, AC power is on a 50 hz cycle, but I don't know if they use the standard 29.97 framerate or if that's what DV-PAL is for.
Unread 15-02-2006, 23:08
PAL runs at 25fps (50 half-frames/second)
http://en.wikipedia.org/wiki/PAL
Unread 06-03-2006, 22:16
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Smile Re: Your animation will NOT be judged...
This is off subject for the Thread, but to keep in the tradition of most other threads, I will post any way.
RE: 29.97 Framerate.
Not sure about that whole light flicker think, which was very creative at worst (maybe technically accurate- somewhere) but my understanding of the Framerate is this: 29.97 framerate is called drop-frame. 30 FPS is call Non-Drop. What this means in 29.97 framerate- you lose .03 of a frame everysecond. This allows the frame rate timing to keep up with "Real time" or clock cycles. (That's Clock as in tell time with a... not CPU Clock Cycles). So for non-broadcast video it doesn't really matter, but when things need to play on TV at a specific time and the time needs to fit into the Show format and not go over time for fear of a portion of the show cutting out mid sentence while the station goes to commercials and such, you need to compensate for true time. I'm not sure why true time cant be achieved with modern technology- perhaps there is a dark hidden closely garded secret in relation to the light flicker . However, it is very similar to leap year as a method to adjust our clocks and calendar to the imperfections in measuring the length of the day.
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
