Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 12-02-2006, 21:18
Andrew Blair's Avatar
FRC #0306 (CRT)
User Processor Execution Time
How long does it take a single loop to execute when called in user_routines.c?
Basically, in Process_Data_From_Master_uP, I am calling a function that multiplies my interrupts by 38, to get interrupts a second, and eventually, revolutions per second. If I call this important function in Process_Data_From_Master_uP, will it execute at a consistent 38 Hz? Or do I need to put it in User_routines_fast.c? And How would I do that? Thanks much.
unsigned int Get_Wheel_Speed(void)
 return((Get_Interrupt1()*38));
-Sir Francis Bacon
-Albert Einstein
Unread 12-02-2006, 21:52
Re: User Processor Execution Time
The frequency is consistent, but only on average. You can't count on it being exactly 26.2 milliseconds between calls. And if there's a communication glitch, one or more calls might be skipped entirely.
For what you're doing, you probably should use a timer interrupt.
Cup Finals Time Lil' Lavery Chit-Chat 6 09-06-2004 20:15
**FIRST EMAIL**/Team Forum Dates and Locations Announced! Damian Manda FIRST E-Mail Blast Archive 2 22-05-2004 10:08
All right - it's that time of the year for... Matt Attallah Chit-Chat 6 08-04-2004 01:20
time change... David Kelly Chit-Chat 9 01-11-2001 11:20
