Go to Post (i would watch out for those jag's if i were you) - Scott Bahl [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 12-02-2006, 21:39
Vince's Avatar
Vince Vince is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1994
Vince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond repute
Ball Speedometer - LabVIEW Application
I wrote a LabVIEW VI to measure ball speed using two IR sensors spaced a few feet apart detect when a ball passes by. The NI USB 6009 interface measures the analog voltge from each sensor (using a pull up resistor in series with the signal). A LabVIEW VI is used to determine the time difference between the leading edge of the signal from each IR sensor.
The Block Diagram of the VI is not elegant (and I'm sure there are cleaner ways to code the VI) but the front panel looks pretty clean.
Front Panel View of the LabVIEW Speedometer VI
I'd be happy to send the VI to anyone that would like to give it a try with their system & shooter - just drop me a note and I'll email the VI.
Unread 13-02-2006, 11:13
MRKaschner MRKaschner is offline
Mark Kaschner
MRKaschner is an unknown quantity at this point
Re: Ball Speedometer - LabVIEW Application
That is a nice looking Front Panel and a great application...thanks for sharing with other users!!
Mark Kaschner
Applications Engineer
Unread 14-02-2006, 21:59
Ray Gitchell Ray Gitchell is offline
FRC #0525 (SwartDogs)
Ray Gitchell is an unknown quantity at this point
Vince,
Team 525 would like to try your ball speed VI.
Could you please send a copy?
We have the USB 6009 also.
Thanks, Ray Gitchell
Unread 28-02-2006, 17:40
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
I think this would be an excellent thing for NI Pilot Program teams to build if you have the means - I can see something like this being in high demand during a regional. I'll provide a LabVIEW VI that does something similar if teams would like to build one (I'll even provide some crude instructions on building one). Anyone a taker?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 01-03-2006, 12:13
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
SPAM (Team 180) should have their's up and running at the Florida and Palmetto regionals. Look for them in the pits or near the practice field(s).
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 01-03-2006, 12:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
From what I see and remember, this is the one Vince made and will be used at official competitions during inspection.
This video was taken at the UTC scrimmage the Saturday before ship date, and was tested and used a bunch of times.
http://www.zippyvideos.com/482313575...crimspeedchkr/
Unread 04-03-2006, 10:53
-Danny
Danny,
Could you please send (or post) a copy of the vi if you received one. Team 525 would still like to try a ball speed tester.
Thanks, Ray
Unread 13-03-2006, 18:32
Vince's Avatar
Rookie Year: 1994
Hi Ray -
I didn't see the earlier post you made (must have been building a robot or something) - if you send me an email at vw-AT-alum.mit.edu (maybe the phisher programs won't spot this as an email adress with the -AT- in the note) I'll shoot you out the VI - the program and rig seem to be helpful at the Regionals I've been at - Cheers - Vince
CMUCam2 LabVIEW Application problem itsdamoose LabView and Data Acquisition 1 09-02-2006 20:59
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
