Go to Post Be not afraid, go forth and multiply. - Pat Major [more]
Unread 13-02-2006, 07:47
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
How does disabled mode work?
I am interested in building a loop that calibrates the gyro bias while the robot is disabled.
1) Is that legal, as long as there are no PWM outputs, etc.
2) What part of the code is running while the robot is disabled? Process_Data_From_Master_uP()? main()? Process_Data_From_Local_IO()? Is statusflag.NEW_SPI_DATA ever set to true? Does that matter, if the gyro is handled in Process_Data_From_Local_IO()?
Thanks in advance,
Robinson
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 13-02-2006, 08:06
Re: How does disabled mode work?
From the point of view of the robot code, the only thing that's different is the value of the disabled mode flag. All the routines run; all the inputs work. Serial communication, analog inputs, and digital I/O all function exactly the same whether or not the robot is disabled.
None of the actual relay or pwm outputs will be active when the robot is disabled. That's all there is to it.
Unread 13-02-2006, 09:17
AKA: Robinson Levin
Thanks for the fast reply.
Is operating sensors during competition while disabled legal? Desirable?
What about the camera? It communicates using serial, but has PWMs on board. Can I adjust these? If so, can Kevin's code be reworked to lock on pre-match?
Thanks,
Robinson
Goethe, Faust
Unread 13-02-2006, 09:23
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
They have ruled that it is legal to operate the camera servos from the camera's on board PWM controls before the match starts. We did this last year, and the robot would determine which vision tetras was out before the other teams finished setting up .
Unread 13-02-2006, 11:25
It's perfectly fine to read sensors while the robot is disabled. In fact, sometimes it's important to do so. For example, when you're using a solid-state gyro, you need to calibrate it before you start moving, and you need to read it consistently in order to track your heading.
The camera is considered a sensor rather than an actuator. If its servos are only controlling the direction it's looking, having those servos active even when the robot is disabled is permitted.
Changing this year's camera code to use camera-connected servos is neither trivial nor obvious. I think it might actually have worked better if I had started with last year's code instead.
Unread 13-02-2006, 11:47
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by gnirts
...can Kevin's code be reworked to lock on pre-match?
Yes, it can. I started working on this a few weeks ago, but my day gig sucked away any free time I had to work on it. But now I can. I have a new version of tracking.c that does all servo manipulation through two new functions. I haven't had a chance to test it yet, but if you'd like to, here's a link: http://kevin.org/frc/frc_camera_beta.zip. Please report back here with the results of testing. I'll be able to work on this tonight, but it would be most helpful if I knew this code worked (or not) before I leave work.
-Kevin
Kevin Watson
http://kevin.org
Designs that would never work... Cyberguy34000 Technical Discussion 60 09-01-2007 20:56
RC getting spontaneously disabled Shu Song Control System 14 12-02-2005 21:00
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
A serious (FATAL) error in the FRC documentation (competition_mode) KenWittlief Programming 17 29-03-2004 13:47
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
