Go to Post studies have shown that postive feedback works better. Driver should get a shock until he obtains target lock, then it stops. Performance incentive :^) - KenWittlief [more]
Unread 13-02-2006, 09:57
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
Re: Backwards motor
yes reversing output wires is easiest for coding, then to compensate for bias, drive the robot using pure code (no joystick) with pwm1 being left and pwm2 being right motors...
code:
pwm01 = 175;
pwm02 = 175;
then see if the robot pulls to the left or the right... if so adjust the numbers until it drives straight... you might end up with 175:180 .. then take the difference (5) and add it automatically to the drive code (pwm02 = p2_y +5) so it will send the joysticks value to the pwm but add 5 to compensate for bias.
or for somethign more complicated, use a percentage (as you drive faster add more to the joystick to compensate)
hope that helps
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
Unread 13-02-2006, 12:56
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Backwards motor
Be careful with that method, if you push the sticks full forward you (theoretically) get 254, adding anything more than 1 to that will cause it to wrap around to 0 and trigger a high speed reversal, that'll make driving kind of difficult.
You could put a software cap that limits joystick input to 254 - bias, whatever it ends up being, then the slower motor will reach full speed and the faster one won't, but that isn't perfect either. A percentage based bias adjustment, plus a sanity check to prevent wrap around would be a good solution.
Matt Krass
Low Cost Planetary Gearbox Source... Joe Johnson Motors 32 14-11-2006 18:02
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
DC motor design project Ian Mackenzie Motors 0 29-01-2005 13:30
