Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Unread 13-02-2006, 11:32
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Organize EasyC functions in a fashion we like?
Can anyone tell us if it is possible to re-arrange your functions you create in EasyC to a method more organized to us?
Or is this a "C LINKER" issue?
Can we re-arrange it somehow? We would like to group all of our input_*.* functions closer together because our function list is getting long. It would be nice not to have to hunt for them in the function list or put them alphabetical order.
Is there some file we can edit to change this around like we like them?
See screen shots of out of order function, (they appear in the order they are created and no organization in functions compared to another program written in ladder that has some organization in the sub routines.
ID:	3976  Click image for larger version
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 14-02-2006, 08:33
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Organize EasyC functions in a fashion we like?
You can''t change the order of functions in EasyC.
Though I think its a good idea.
Unread 14-02-2006, 23:11
Controls Engineer
AKA: chakorules
It would be handy if we could. We think about functions to create in a "not so orderly" fashion, this tends to mix up the functions we have created.
Favorite CD quote:
Unread 20-02-2006, 18:53
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
They're listed in a FIFO (First In, First Out) manner, so they show up in the order you add them, as you noted. You can't simply rearrange them (this is an EasyC UI problem), so the workaround is to remove them all, then re-add them in the order you want. I recommend saving first, just in case.
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
Calling C functions from EasyC koenig3456 Programming 4 27-01-2006 16:03
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
