Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Unread 13-02-2006, 14:39
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Gear Sensor
Anyoe now how to use/get the input from the gear tooth sensor? What I'm trying to do is make sure a gear doesn't drop below a certain speed. Any relavant tips would be great.
Unread 13-02-2006, 14:58
Re: Gear Sensor
Connect its output to a digital input (any of 1 through 6) on the Robot Controller, then configure the input to cause an interrupt. Increment a counter whenever the interrupt occurs. Separately configure a repeating timer interrupt. Each time the timer goes off, save the value of the gear tooth counter and then reset it to zero for the start of the next time period.
That's the short version. If you don't understand interrupts, ask again.
Unread 14-02-2006, 07:05
winners winners is offline
winners is an unknown quantity at this point
Re: Gear Sensor
I dont understand the interrupts, can you please explain it to me?
Unread 14-02-2006, 09:56
Re: Gear Sensor
See the thread at http://www.chiefdelphi.com/forums/sh...ad.php?t=43244 for information on how to count gear teeth using interrupts. Pay special attention to the post by b_mallerd.
For using timer interrupts, see the Timers White Paper: http://www.ifirobotics.com/docs/time...004-jan-14.pdf
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
Gear Sensor Competition Usage Feedback de_ Electrical 6 15-05-2005 15:15
