Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 13-02-2006, 15:50
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
pic: Team 1701 Teaser
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 13-02-2006, 15:52
viking1902's Avatar
viking1902 viking1902 is offline
Team Viking/Head Mechanical
AKA: chuckie
FRC #1902 (EXPLODING BACON!!!)
viking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of light
Send a message via AIM to viking1902
Re: pic: Team 1701 Teaser
i was waiting for someone to use a trash can! awesome job guys!
Unread 13-02-2006, 16:38
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
looks good, but just one question. How visable are the balls?
<G13> balls contained in ROBOTs at the Start of a match - Each ALLIANCE will start a match with 40 balls. Each ROBOT may contain up to 10 balls at the start of a match. Any balls not contained within the robot will be evenly distributed between the alliance ball corrals. All of the balls must be contained within the ROBOT's 28" x 38" x 60" starting volume and must be clearly visible from outside the ROBOT. The Head Referee will require that balls outside of the starting volume be removed. It is the responsibility of the head referee to verify that this rule is satisfied prior to the start of the match.
Unread 13-02-2006, 16:44
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
thats nothing that a good hour with a drill cant fix . . great job 1701.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 13-02-2006, 16:47
matt101 matt101 is offline
matt101 is an unknown quantity at this point
I would suggest glueing pictures of balls on the outside of the trash can, the refs will never know the difference. No, in all seriousness where do they come up with these rules? Like why do the balls and brain etc have to be visible?
Unread 13-02-2006, 16:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The balls have to be visible so that they may be able to quickly determine that your robot is starting with no more than the 10 allowed balls. The robot controller must be visible for arena troubleshooting.
Refs can look down into the hopper and see the balls -- this robot is fine as is in that respect. I would investigate shielding the shooter from contact with other robots, however.
--Madison--
...down at the Ozdust!
Unread 13-02-2006, 18:14
in between teams
AKA: Luke Van Oort
I like the chain pathing on your 4WD. However, I don't think you guys will be able to turn. Those IFI wheels have very high traction, making a skid steer's job much harder. The drivetrain geometry doesn't help much either, as having a longer wheelbase (distance between front and rear wheels) than track width (distance between wheels) makes it near impossible to turn without hopping, if you're using the same wheels F/R.
Team 1219: 2009 - Mentor
Unread 13-02-2006, 18:18
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I wouldn't think it would need much more protecting.
Unread 13-02-2006, 19:17
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Pretty Awesome and it looks very kewl. Don't change it!
Unread 17-02-2006, 19:58
Pontchartrain's Avatar
Pontchartrain Pontchartrain is offline
AKA: Joe
FRC #1701
Pontchartrain is an unknown quantity at this point
Yes, Shiney is a very sexy beast. Though that old picture can't do him justice.
Fort Pontchartrain d'Étroit
Founded Anno Domini Seventeen Hundred and One
Team 1701 - Absoutely Nothing to do with Star Trek
Unread 11-03-2006, 22:13
Alastan's Avatar
Alastan Alastan is offline
Team Role: Student
Alastan is an unknown quantity at this point
Send a message via AIM to Alastan
We should put up a new pic then, one that shows off Shiny as a "sexy beast," as you put it.
Unread 12-03-2006, 13:39
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
hey you guys did well at GLR
I'm proud to be a...
Unread 14-03-2006, 15:13
Alastan's Avatar
Team Role: Student
thanks
"Never judge a person until you walk a mile in their shoes... that way, when you do judge them, you'll be a mile away, and you will have their shoes!"
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team #1382 Teaser - Gear Box tribotec_ca88 Extra Discussion 6 22-01-2005 20:02
