Go to Post Teamwork, dedication and friendship have a lot of play in all factors of life, including a robot contest. - tenthirtythree [more]
Unread 13-02-2006, 16:44
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: pic: Team 1701 Teaser
Originally Posted by Vince lau
looks good, but just one question. How visable are the balls?
<G13> balls contained in ROBOTs at the Start of a match - Each ALLIANCE will start a match with 40 balls. Each ROBOT may contain up to 10 balls at the start of a match. Any balls not contained within the robot will be evenly distributed between the alliance ball corrals. All of the balls must be contained within the ROBOT's 28" x 38" x 60" starting volume and must be clearly visible from outside the ROBOT. The Head Referee will require that balls outside of the starting volume be removed. It is the responsibility of the head referee to verify that this rule is satisfied prior to the start of the match.
thats nothing that a good hour with a drill cant fix . . great job 1701.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team #1382 Teaser - Gear Box tribotec_ca88 Extra Discussion 6 22-01-2005 20:02
