Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 13-02-2006, 10:25
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
Re: CMU Camera kills robot controller if not found.
Originally Posted by BradAMiller
This should be fixed in an upcoming release of EasyC, but to try it for now, you can download the library from my web site, unpack the .zip file and replace the copy of WPILIb.lib inside of the EasyC directory C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722 with the copy of WPILib2k6.lib from the .zip file.
Will this version of the WPILIB.lib work for the 18F8520 as well?
Unread 13-02-2006, 10:36
AKA: Brad
#0190 ( Gompei and the Herd)
Yes, there are two directories - one for the 2k5 controllers and one for the 2k6.
Brad Miller
Robotics Resource Center
Unread 13-02-2006, 10:39
Thanks Brad!
Just to be Clear: copy the same version of the new WPILib to both :
AND
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8520
so the update for the camera can be used on the 2006 & 2005/4 RC units.
Unread 13-02-2006, 15:11
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Thanks Brad!
AND
Hmmm....I'll tell you what I did:
Unpack the .zip file and replace the copy of WPILIb.lib inside of the EasyC directory C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722 with the copy of WPILib2k6.lib from the .zip file. (You'll need to rename WPILib2k6.lib to WPILIb.lib and over write the OLD "WPILIb.lib" file. Backup the old one FIRST. You need to do this for both 2005 controller and 2006 sub directories.
18F8722 = 2006 controller
18F8520 = 2005 controller
These two files need updated:
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722\WPILIb.lib
with
WPILib2k6.lib (rename this to WPILIb.lib, copy over the top of the old after backing it up)
and
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8520\WPILIb.lib
with
WPILib2k5.lib (rename this to WPILIb.lib, copy over the top of the old after backing it up)
That should take care of you.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 13-02-2006, 17:25
AKA: Brad
Thanks Brad!
AND
Be careful... there are two version of WPILib. One is for the 2k6 robot controller and the other is for 2k4-5. If you copy the same version to both directories, one will not work.
Brad Miller
Unread 18-02-2006, 15:40
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
If you remove your camera from the system, keep your serial connnection plugged into the RS 323 or whatever it is called port, and just not plug the PWM cable into it. Then there will be no problems at all, since it is getting serial data, which means it will initialize, and read, and get 0 data.
Removing the PWM cable to Serial board causes our robot to also lock up and not go anywhere.
My Blog!
Unread 27-03-2006, 14:30
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
This issue has been fixed in the current version of easyC.
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Camera not found! SpeakerSilenced Programming 0 21-02-2005 12:54
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
