Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
View Poll Results: What tools will you use to get to 120 lbs?
Lead -more than 10 lbs under 16 13.68%
Steel-more than 1 lb under 6 5.13%
Nothing-at or just under 18 15.38%
Drill-less than 1 pound over 3 2.56%
Holesaw- 1-5 lbs over 18 15.38%
Hacksaw- 5- 10 lbs over 7 5.98%
Jigsaw- more than 10 lbs over 9 7.69%
Remove mechanisms 3 2.56%
Other--state in thread 7 5.98%
Combination 16 13.68%
There's a weight limit??? 14 11.97%
Voters: 117. You may not vote on this poll
Unread 13-02-2006, 14:38
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: What tool are you using to make weight?
well team 1745 weighs in at 73 lbs now . . . I have no idea if this is bad or good.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 13-02-2006, 14:53
IraJason IraJason is offline
In Search of "Bang Head Here" Sign
AKA: Ira Goldberg
FRC #3632 (D-Tecs); FRC #1712 (Dawgma)
IraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant future
Send a message via AIM to IraJason Send a message via MSN to IraJason
Depends on how much of a robot you got. If you just have a chassis that can move around, then that seems pretty good. If that is your near finished robot's weight, then I am amazed... and its time to add a few pounds so it doesn't get pushed all over the place by other robots.
Unread 13-02-2006, 15:34
Stuart's Avatar
#include coffee.h
thats the near finnish weight . . with a shooter, a basket that can hold 20+ balls, and a 320 degree rotating turret(auto tracking of course).
so how much does lead cost?
Unread 13-02-2006, 17:29
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Originally Posted by EricH
All right, so what tool(s) are you currently planning to use to get your robot to 120 lbs as we go into Week 6?
Well. we haven't been that concerned woth weight, but we are usung our Bridgeport and CNC to drill/ mill lightening patterns in our parts. We will probably add weight later.
Schneidie
Unread 13-02-2006, 17:32
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
we use good ol' unibits as seen here. it does the job.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 13-02-2006, 17:37
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
2" Lincoln Bit and a revamped pneumatic air tool.
Whine and Cheese party. After the whine of the drill, everything looks a HOLE lot like Swiss Chees.
Unread 13-02-2006, 18:37
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
The only tool we use is good design practice and a really annoying person who's job is to ask constantly "How much does that weigh???" It looks like we will be 10-20 lbs under when we get done, so we've quit worrying about what things weigh. My biggest concern right now is that there is no good place to put the lead...
Unread 13-02-2006, 18:59
So far, 57 pounds. We just need to get everything onto the drivebase that we weighed and we'll be over. I'm hesitant to guess by how much.
Unread 13-02-2006, 20:08
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Used brass where we are is $1.50 lb it cuts easy and has far less safety issues than lead. BTW it is more dense than the cast (iron) weights on the back of our studio cameras a 16 lb chunk is about 1 x 4 x 6 unless my memory has lost it again.
Unread 13-02-2006, 20:12
Hunter Levesque Hunter Levesque is offline
FRC #0177
Hunter Levesque will become famous soon enoughHunter Levesque will become famous soon enough
Send a message via AIM to Hunter Levesque
Wow, our team is over the weight limit year after year. We have to drill holes in the sheet metal to lose weight, and you guys are adding weight? I never knew other teams had it like this.
Unread 13-02-2006, 20:39
in between teams
AKA: Luke Van Oort
One letter: H. We plan to use lots and lots of H. Seriously, my team... okay, I've pretty much ignored the wieght limit (can't speak for the launcher team) since we're going to be pretty small this year (under 3 feet most likely yay!) and the bigger parts are aluminum. But, if worse comes to worse, I'll leave it up to the launcher people. I'm going to wire the robot for neatness and order (I hope) while maintaning shorter runs. It is the lovely convergence of things needed: order, lower resistance, and weight. Nice organized, short runs helps them all... and gives me another thing to do. (I don't have much to do right now since the drivetrain's done and it was my sole responsibility)
Team 1219: 2009 - Mentor
Unread 13-02-2006, 20:41
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Team 222 has drilled 352 holes tonight alone. All holes were at least 9/16" of an inch in diameter ranging up to 2.5."
That does not count any of hundreds of previously drilled holes.
We have hack-sawed a decent amount too.
This is going be fun getting under weight
EDIT:
Add 27 to that number (the night goes on.) 377 total holes. 1 night.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 13-02-2006, 20:47
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Cool Re: What tool are you using to make weight?
I don't have any words to explain what i feel after reading all these posts. Luckily our team seems to build the heaviest robot in the world, and than throw away 4 robots worth of parts to finally get the weight reduction we need. Our ball holder weighs 1/8 what it weighed earlier! Now it weighs something rediculously low. Our ball launcher was like 50 lbs, I was cleaning up the new launcher and I can guarantee it only wieghs about 5-10 pounds now! As far as I know, our team never needs more weight, we need less weight and more time!
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 13-02-2006, 20:51
Mike Nawrot's Avatar
Mike Nawrot Mike Nawrot is offline
NAwrot (a.k.a. jub jub)
AKA: Mike
FRC #0011 (MORT (Mount Olive Robotics Team))
Mike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really nice
Send a message via AIM to Mike Nawrot
Team 11 seems to have always had problems with being over weight from what i've heard. being my second year, i can't list all the examples of over weight robots in the past 10 years of the team. but i can say that last year, our telescoping/articulating arm made completely out of cnc'd lexan side panels and foam filled lexan tubing came in at 16.6 pounds to heavy, and since it was already completely milled out for maximum weight savings, there was no change of using it. luckily, we had a back up arm made of aluminum, with no articulation, that still had to be drilled out to save weight. learning from last years mishap of people drilling off centered holes and sacrificing structural integrity, when we came in at 116 without electronics, we hole sawed our gator board (top secret sign making material that has been implimented into a robot), and i was put in charge of drilling approximately 300 half inch holes in our aluminum frame, 1 inch apart, dead center for maximum strength. we've come in around 110 after switching from pvc rollers to foam filled lexan rollers, and after sawing away any excess aluminum on our frame. now its time for electronics....... hopefully we won't need to drill anymore..... my wrist is still sore from all the drilling and center punching.....
Unread 13-02-2006, 22:08
Jeff Pahl's Avatar
The lead comment was a humorous reference to the poll option for being over 10 pounds under. For safety reasons I would never recommend lead, as it now seems to be considered a hazardous material in almost any condition. In the past we have used barbell plates, and that is probably what we'll end up using again. The trick with this year's design will be finding a good place for them that doesn't get the CG up too high. Maybe I can convince the students they need to add the air compressor
Drive-train / chassis weight Andrew Schuetze Technical Discussion 19 07-02-2006 16:51
Cool new 2004 Score Calculator Tool Jeff Debes General Forum 7 02-03-2004 15:46
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
