Go to Post Isn't the professional level for us called a job? - CalTran [more]
Unread 13-02-2006, 20:25
Umm Errr...
psychotic compiler
I figured it out and was right. Apparently the compiler is too stupid to notice if you leave off a semicolon in the last line of a file. This causes major problems when it tries to figure out why it can't compile things.
There's nothing like a compiler that has a list of known problems 24 pages long! I'm not kiding. Look in \mcc18\MPLAB-C18-README.txt
1139 Alumni
Unread 13-02-2006, 20:33
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: psychotic compiler
Originally Posted by Rickertsen2
My compiler has gone psycho for real this time. It insists that there is an error on the first non comment, non compiler directive line of a certian file. If i comment out the entire file or remove it form the project, it picks another file and does the same thing. After several iterations of removing files, it started complaining about LIBRARY FILES!!!! I had this problem once before and the only way i was able to rectify it was to go back to a previous version. Unfortunately i havn't kept any backups this year, so that is not an option. Does anybody know a fix.
I suspect that there is a syntax error somewhere in my code, that the compiler does not know how to properly identify.
Have you tried good old Ctrl + F10?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 13-02-2006, 20:47
Umm Errr...
my friend paul tells me this is a "known standard bug of the c language".
"Java 1.0 also suffered this bug"
"The parser falls off the end of the line into another file and then completes it at the next ";" it finds that isnt in a compiler directive or comment"
1139 Alumni
Unread 13-02-2006, 21:32
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Your fault for leaving off a semicolon in the first place .
One could say this is an inherent flaw with C I guess. Lines are ended with a semicolon so that stuff like this is possible:
int i =
192984392429
298349384394328;
If your error falls at the end of a file, you are supposed to look for a semicolon one has missed.
My Blog!
I need a easy & free c compiler aksimhal Programming 7 31-01-2006 22:05
C18 Compiler v.3.00 Problems prograid Programming 6 10-01-2006 22:10
C18 v2.4 compiler location b_mallerd Programming 1 14-12-2005 16:43
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
