Go to Post Without the game, there is no FIRST ... period. - Paul Copioli [more]
Unread 13-02-2006, 20:39
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Question Large CIM breaker trouble
I've searched and come up with some interesting threads... but as far as I can tell, this is the only question like this Sorry if it isn't
We attached the large CIM for our motor today, and We continually Flip breakers before it gets up to speed. We tried switching joysticks, and it helped for a throw or two (which doesn't make sense to me). When we slowly ramp the speed up, It gets to a higher RPM before blowing the breaker, but the breaker still flips.
We went back and made sure that nothing mechanically was binding, and everything was fine. We also did a check of our electronics, and everything is fine, except that we are temporarily using a smaller wire than we should. I would think that using a smaller wire would cause the breaker NOT to flip... But at this point I'm out of Ideas. We made sure to use the correct everything but wire running from the motor to the speed controller. The wire leading to the large CIM is coiled next to the 4 small CIMS we use, and when we aren't running them... It seems that the problem's severity lessens. But I don't know...
Any ideas would be greatly appreciated
Unread 13-02-2006, 20:41
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Large CIM breaker trouble
In addition, its a 40 amp breaker we're using.
-Sir Francis Bacon
-Albert Einstein
Unread 14-02-2006, 02:02
Does it happen when the motor is not connected to anything (mechanically)?
Unread 14-02-2006, 09:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I assume this is for a shooter. How big and heavy of a wheel are you using, and what gearing are you using?
Also, it only working for a throw or two makes perfect sense. The breakers are thermal buildup sort of devices. If you look at the spec sheet, they're only guaranteed to trip at 135% overload. If you're operating between 54 and 40 amps, then the possible trip time is 6 seconds to infinity. So you might be drawing enough amps to make it trip after 15 seconds or more. Or you might be spiking it with 70 amps or something for a few tenths of a second, but the heat isn't dissipating, so it'll trip after a few of those spikes. It sounds to me like you're trying to drive too large a load with too much voltage, really. I know my team is planning on adjusting our maximum commanded PWM based on the RPMs of the CIM to keep from tripping the breaker.
Unread 15-02-2006, 07:25
Cody and Andrew,
This is an odd case but there is a good way to check out all the possibilities. First, have you tried a different breaker, there are production problems from time to time. Second, disconnect the motor wiring at the output of the speed controller and power up. If the breaker still trips, it is the speed controller or the wiring feeding it (double check the speed controller is correctly wired.). Third, replace the wire between the motor and the controller, using the smaller guage may have melted the insulation between conductors somewhere causing a short. Finally, you could have a bad motor or the mechanism the motor is attached to has a mechanical problem.
Unread 16-02-2006, 17:17
robotoby35138's Avatar
robotoby35138 robotoby35138 is offline
FRC #1522
robotoby35138 can only hope to improve
Exclamation Re: Large CIM breaker trouble
do you reset the breaker or just the robot because that is what we had a problem with?
Large CIM Creating Radio interference Alex Burman Motors 1 13-02-2006 14:21
Large CIM Motor Bias Ceal Craig Motors 3 09-02-2006 10:20
Large Cim Motor? Fishdude404 Motors 1 27-01-2006 22:36
Breaker for Large CIM Gamer930 Electrical 4 27-01-2006 07:52
Large CIM Motors - Removing the sprocket PuiChi Motors 5 13-01-2006 16:01
