Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 13-02-2006, 20:47
Umm Errr...
Re: psychotic compiler
Originally Posted by Rickertsen2
I figured it out and was right. Apparently the compiler is too stupid to notice if you leave off a semicolon in the last line of a file. This causes major problems when it tries to figure out why it can't compile things.
There's nothing like a compiler that has a list of known problems 24 pages long! I'm not kiding. Look in \mcc18\MPLAB-C18-README.txt
my friend paul tells me this is a "known standard bug of the c language".
"Java 1.0 also suffered this bug"
"The parser falls off the end of the line into another file and then completes it at the next ";" it finds that isnt in a compiler directive or comment"
1139 Alumni
Unread 13-02-2006, 21:32
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Your fault for leaving off a semicolon in the first place .
One could say this is an inherent flaw with C I guess. Lines are ended with a semicolon so that stuff like this is possible:
int i =
192984392429
298349384394328;
If your error falls at the end of a file, you are supposed to look for a semicolon one has missed.
My Blog!
I need a easy & free c compiler aksimhal Programming 7 31-01-2006 22:05
C18 Compiler v.3.00 Problems prograid Programming 6 10-01-2006 22:10
C18 v2.4 compiler location b_mallerd Programming 1 14-12-2005 16:43
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
