Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 13-02-2006, 20:04
354.FIRST 354.FIRST is offline
FRC #0354
354.FIRST is an unknown quantity at this point
Question What is T_Packet_Data.my ??
Help
In terminal.c there is the following code:
// does the camera have a tracking solution?
if(T_Packet_Data.my == 0)
how exactly does T_Packet_Data.my give us whether the camera has found a centered target? Is this what we should be using to know if our camera has a target in sight and centered?
thanks
-354
Unread 13-02-2006, 20:08
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: What is T_Packet_Data.my ??
This is the y axis location of the "blob" (the green target) on the cameras view. If there is no blob, it is zero. Theres no specific variable saying if something is in view, but this works just as well.
http://www.mikesorrenti.com/
Unread 13-02-2006, 20:18
FRC #0354
Thanks.
What's the best way to tell if the camera has a centered target?
-354
Unread 13-02-2006, 20:21
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Well, logically, if the blob was centered in both the x and y dimensions, it would be safe to assume that the camera was centered on the target.
Now how could you tell how where the blob is....
Unread 13-02-2006, 20:27
Mike's Avatar
AKA: Mike Sorrenti
Originally Posted by 354.FIRST
Thanks.
-354
I'm not totally sure where Kevin found this information (maybe he can elaborate more) but in tracking.h I see
// parameters for CMUcam2 with OV7620 camera module
#define IMAGE_WIDTH 159
#define IMAGE_HEIGHT 239
So from this data you can figure that the middle point of the field of view is (79, 119) which, is also the value of the defines PAN_CENTER_PWM_DEFAULT and TILT_CENTER_PWM_DEFAULT.
So, what you want to do is get T_Packet_Data.my the closest you can to TILT_CENTER_PWM_DEFAULT and T_Packet_Data.mx to PAN_CENTER_PWM_DEFAULT.
-Mike
Unread 13-02-2006, 20:32
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
That's what I thought too, but in debugging, it looked to me like mx and my DO NOT get cleared when the target is lost. As I noted in another thread, I changed the if(T_Packet_Data.my == 0) tests in tracking.c to if(T_Packet_Data.confidence <= 1) to make the tracking more reliable.
Unread 13-02-2006, 20:44
FRC #0354
thanks for all the help y'all.
Totally saving my butt.
Can you point me to that other thread you mention? I am not finding it.
-354
Unread 13-02-2006, 21:01
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
-354
http://www.chiefdelphi.com/forums/sh...897#post448897
Unread 13-02-2006, 21:30
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Ehm, where did you get that from? They get cleared when there is new data from the camera, and if the data from the camera contains a y that does not exist, it will be set to 0, as in it can not find it.
That is at least what I got from the code, and the fact that each time the slow loop is run data is retrieved from the camera.
My Blog!
Unread 13-02-2006, 21:44
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Seriously? I've never seen it do that, but I'll look into it. I'm working on an updated tracking.c and I'll incorporate the fix(s) when I understand the problem better. BTW, did Rob Steele know about this?
-Kevin
Kevin Watson
http://kevin.org
Unread 13-02-2006, 21:46
FRC #2429
Use the error values for this.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-02-2006, 22:33
FRC #2429
Greg, are you saying that the CMUcam2 will occasionally send a t-packet with a non-zero value for .my when it does *not* have a tracking solution?
-Kevin
Kevin Watson
http://kevin.org
Unread 13-02-2006, 23:25
Mike's Avatar
AKA: Mike Sorrenti
-Kevin
I don't think he is saying that it sends a t-packet with a non-zero value for .my/.mx but rather that the .my/.mx that is already stored does not change it's value when the image of a blob is lost.
Unread 13-02-2006, 23:26
AKA: Bert JW Regeer
It however does when it gets new information from the camera, so that would make no sense.
My Blog!
Unread 13-02-2006, 23:30
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
After reading what Greg found in the other thread, Saturday our programmer changed the terminal routine to dump out mx, my, and confidence and we ran tests. We saw non-zero mx, my values with confidence up to 6 or so with the target outside the camera's field of view. When the target is in the field of view the confidence was as low as 140 but was mostly well over 200.
The room the tests were run in had the camera on a 3' table, rows of white flourescent lights were 8'-9' up, and the target was at 3'. We determined the camera was picking up the white lights and putting those in the mx, my values. When we put the target on the floor and limited the tilt up angle the camera no longer picked up the white lights.
Our programmer changed the code to use confidence and it worked perfectly even with white lights in the field of view.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
