Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Unread 13-02-2006, 10:20
dagger dagger is offline
FRC #1208
dagger is on a distinguished road
How to lose that extra weight (Was: Major Help!!)
our robot is 15 lbs over weight. we need all the advice we can get to help us LOSE THE WEIGHT! any suggestion would be appreciated...thanks.
Unread 13-02-2006, 10:25
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
Re: Major Help!!
If you posted a picture, it would probably help others offer advice.
Unread 13-02-2006, 10:26
Re: Major Help!!
are you aware that they changed the rules: this year the robot is weighed withOUT the battery?
Unread 13-02-2006, 10:28
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Major Help!!
If you are using the kit frame, drill out all of the holes in it to one drill size larger (I think its 3/8 not sure...) this takes about 3-4 lbs out of the frame while keeping the integrity.
Lexan panels love hole saws and so do metal plates as well as wooden parts.
Wheels could use some holes drilled in them, not too many though.
Gears should be turned down to a smaller hub, but not too small. And then holes can be drilled in them as well.
Next is the electrical where wires can be shortened to exactly the length needed so as not to have extraneous wiring.
Then after that replace all of your team identification panels and things with a simple piece of paper, nothing fancy.
Round the corners on everything, surprisingly this takes off quite a bit.
Bolts that are too long should either be cut off or replaced.
Steel shafts should be traded out for aluminum ones if there isn’t a large load on them.
If this doesn’t work then take off some features or remove the least necessary structural supports (not advised). Just drill holes until it looks like Swiss. You wont be the only one!
Be sure not to weigh the robot without the 12V battery and without the bumpers. The backup battery must still be on the robot durring weigh in.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 13-02-2006, 12:40
Richsgt Richsgt is offline
AKA: Rich
FRC #0836 (Bobcat Robotics)
Richsgt is a jewel in the roughRichsgt is a jewel in the roughRichsgt is a jewel in the rough
Send a message via AIM to Richsgt
Re: How to lose that extra weight (Was: Major Help!!)
Also you can change out hardware that isn't truly load bearing from steel to aluminum and even nylon nuts and bolts instead of the standard steel.
Electrically, shorten the runs up and even electrical systems to keep the high voltage cables as short as possible, eg victors right next to the distribution block, right next to the battery and motor.
Lastly replace any tubing with thinner walled tubing and lexan with thinner lexan, 1/16 to 1/32
Unread 13-02-2006, 12:53
REVving up for a new season
FRC #2848 (All-sparks)
change you sprockets to aluminum.
www.andymark.biz sells exact replacements to the ones in the kit but are much less in weight.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-02-2006, 12:54
Re: Major Help!!
^ one negation too many here?
the robot is weighed with out the main (big) battery this year, but the backup 7.2 V battery must be present - correct?
Unread 13-02-2006, 13:14
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Major Help!!
Indeed, two years ago our teams bot arrived in Manchester completed but very overweight (it was 20 lbs to start with right before crating, but losing a major part of our arm dropped us to 7 lbs overweight). 7 lbs is a lot to lose if you don't have obvious parts to remove. A large fraction of pit day was spent shedding weight from the bot, to the point where the officials told us not to come back until we were *sure* we were underweight (but let us weigh a bag of parts between other bots, so we figured out our weight loss that way). Too much time was spent with sawzalls and hole saws, arguing with each other about where to cut and how much. And too much time removing every other bolts, almost all the washers, sanding, filing, shortening wires, substituting lighter components, etc. Some of the saga was capured here. (As an aside, we were a regional finalist at Palmetto later that season).
Seriously, I'm glad you're removing weight now, since I don't recommend this approach. Lose the weight now, and not later.
Unread 13-02-2006, 13:51
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
It's late in the building season but re engineering certain components give you the chance to improve upon them as well as losing weight...
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 13-02-2006, 14:07
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
you can save yourself from drilling speed holes by meerly replacing whatever material sheet you have with something thinner. Just think about how many speed holes you need to drill before you cut the weight of something in half.
Unread 13-02-2006, 14:20
DjAlamose's Avatar
AKA: Teh Albie
Re: Major Help!!
yeah sorry about that. I took one quick look over this before i posted and ended up with a double negative, most of the time i end up with a tripple negative.
2004 GLR Champs
Unread 13-02-2006, 15:35
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
327 1/2" holes in 1/8" thick 6061 aluminum makes you loose 1 pound if you have alot of frame material
Unread 13-02-2006, 15:47
BE CAREFULL if you start drilling holes in your robot to drop the weight because you dont realize how addictive it becomes
and sooner or later you end up with stuff like this in your pocket
and you dont remember how it happened!
Unread 13-02-2006, 15:53
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Pay attention to the above quote. 327 1/2 in holes is a LOT of work for 1 lb. Look at a lighter design first.
Remember;
Steel 1rst, then Aluminum, then Plastic
Get the biggest "bang for your buck"
Unread 13-02-2006, 22:38
occra 23.
AKA: ryo
None #1481
does that keep it from ripping up your jeans pockets?
i like the pattern... except i think drilling gets annoying. already ive drilled over 100 1/2in holes all over... we still need to drop more if we want to protect stuff..
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
