Go to Post i swear, if it were april fools day, i would not believe this whole lord dumpling/dean kamen thing...but then again, this is FIRST - sure_smile [more]
Unread 13-02-2006, 21:10
DavidSJohnson DavidSJohnson is offline
DavidSJohnson is an unknown quantity at this point
How to obtain battery voltage from within EasyC
I read where battery level could be obtained using a define within ifi_aliases.h, but that header is not available within EasyC. Is there some way of getting battery level (and maybe backup battery level too) from within EasyC?
Unread 14-02-2006, 00:04
AKA: Brad
#0190 ( Gompei and the Herd)
Re: How to obtain battery voltage from within EasyC
There are two functions recently added to WPILib (the runtime system for EasyC). These functions read the main and backup battery in 1/100ths of volt. The functions are:
unsigned GetBackupBattery(void) and
unsigned GetMainBattery(void)
You need to replace the copy of WPILib to get access to the functions. You also need to add the include file, "BuiltIns.h". The procedure is described elsewhere on this forum. Once you do that, then you can call these functions using User Code blocks.
Brad Miller
Robotics Resource Center
Unread 14-02-2006, 00:05
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I think this is what you're going to need to do:
Go here:
http://users.wpi.edu/~bamiller/WPILib/Versions.html
Download this:
Version 060207
Unpack the .zip file and replace the copy of WPILIb.lib inside of the EasyC directory C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722 with the copy of WPILib2k6.lib from the .zip file. (You'll need to rename WPILib2k6.lib to WPILIb.lib and over write the OLD "WPILIb.lib" file. Backup the old one FIRST. You need to do this for both 2005 controller and 2006 sub directories.
18F8722 = 2006 controller
18F8520 = 2005 controller
These two files need updated:
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722\WPILIb.lib
with
WPILib2k6.lib (rename this to WPILIb.lib, copy over the top of the old after backing it up)
and
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8520\WPILIb.lib
with
WPILib2k5.lib (rename this to WPILIb.lib, copy over the top of the old after backing it up)
Start easyC
Make a USER CODE box or an ASSIGNMENT BOX, but you'll have to type it out, and put this in it:
myvariblebackupbattery = GetBackupBattery()
myvariblemainbattery = GetMainBattery()
There are two new functions to read the main and backup battery in 1/100ths of volt.
Good luck. Hopefully it will work for you.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
