Go to Post If you don't have a hairtie, use a ziptie instead. It works, it's cute, and way geeky. :p - Katie Reynolds [more]
Unread 13-02-2006, 23:17
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
0 or 1?
Is a signal of +5V as opposed to 0V considered a digital 1 or a digital 0? Or does it depend on where? If so, can someone detail when +5V is 1 and when it's 0? I've been confused about this for a while...
Unread 13-02-2006, 23:24
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: 0 or 1?
The digital inputs are pulled to +5v by defualt, so they are 1 when nothing is connected to them. Grounding them sets them to 0.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 13-02-2006, 23:54
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
Re: 0 or 1?
Commonly:
+5V is a digital 1
0V is a digital 0
This is the case in the FIRST robot controller.
There are other protocols and standards that use different voltage levels to represent 1's and 0's, but I'm not aware of anything in the FIRST RC that is not 5V/0V.
As was mentioned before: remember that if you connect nothing to an input, they will default to +5V (not 0V) when the controller is on.
Good luck!
David A.
Unread 14-02-2006, 00:54
Re: 0 or 1?
with digital logic the higher voltage signal is always called 1 or H, and the low voltag signal is always 0 or L.
The thing that is sometimes confusing is some signals are active low. For example, reset signals are usually active low. That simply means when you pull the signal low, the device is reset.
Active low signal names usually have a line over the name (not easy to do in a text editor) or the letter L or N tagged on the end, like: RESET_L.
There are electrical reasons why you would sometimes want a signal to be active low intsead of the normally active high, but it would take about a page of this thread to really explain it.
Unread 14-02-2006, 07:39
Re: 0 or 1?
Never say "always".
What you're describing is called positive logic and is how most digital circuits work, including most of the Robot Controller. However, negative logic exists as well. RS-232 serial communication uses negative logic, with a positive voltage being logic 0 and a negative voltage being a logic 1.
Unread 14-02-2006, 16:22
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: 0 or 1?
the best thing is (i know this isn't quite an answer) to test the device with a printf and find out when it returns 1 and when it returns 0
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 14-02-2006, 16:39
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: 0 or 1?
Originally Posted by Alan Anderson
Never say "always".
It's CMOS (Complimentary MOS) versus MOS (metal oxide semi-conductor for those interested). They are two different methods of constructing gates. But I wont bore you young folk with that.
What you're probably really interested in is this: when that switch is not pressed, what is the RC hearing? When it IS pressed, what is the RC hearing? I use the word
"hearing"
figuratively.
This is most easily tested through the use of the wonderful and beautiful Ms. Printf (I'm in a valentiny mood here). Also, use #defines to good advantage so that you don't have to change a bunch of stuff!
Self-discovery for the win!
Best of luck,
Paul Dennis
