Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
Unread 14-02-2006, 12:28
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Interrupt Maximum before the RED light DEATH?
I've been hunting around for a maximum of interrrupt 1-6 on the 2006 controller and 2005 if they are different. Best I've found is Kevin's documents that say "thousand of clicks per second" on a 40 MHZ PIC chip.
Is there a spec somewhere? Or does that really depend on how much code you have?
We are using the gear teeth sensors which say they have a maximum of 6KHZ of bandwidth, but wanted to make sure we wouldn't kill our CPU if we try and spin the gears up pretty fast. I think we are running around 1176 pulses per second, and the interrupt seems to be behaving. It would be nice to know what are "true" max is before we bury the CPU.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Encoders and putdata theycallhimtom Programming 3 09-02-2006 19:24
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
