Go to Post I had told my new team this joke: "They procrastinate so much, no wonder they're the Heroes of Tomorrow!", but I guess the joke doesn't have any truth in it anymore. They were really on their game this year! - JABot67 [more]
Unread 14-02-2006, 16:23
teh_r4v3 teh_r4v3 is offline
AKA: Rajeev Sharma
FRC #1511 (Rolling Thunder)
Team Role: Student
teh_r4v3 is on a distinguished road
Send a message via AIM to teh_r4v3
Lookup Table Generator GUI
I had some spare time yesterday (gasp!) and decided to whip up a GUI for lookup table generation. (We seem to be making a lot of those.) Manually editing and compiling the Java app I had whipped up earlier in the season was getting annoying, so I decided to make an end to that.
A screenshot is attached (running under Linux). Note that this program is a little abnormal to install, since it requires either Mono or the .NET Framework v1.1. If using the .NET Framework (which I would reccomend under Windows), the Gtk# libraries. (Sorry folks, but I didn't have time to install VS.NET, and there was no way I was laying the thing out by hand. Plus I'm a Linux geek. 8)) So here's the instructions for getting the respective libraries:
To run under Windows:
.NET Framework v1.1 and Gtk# runtime are required. The .NET framework is
available here:
http://www.microsoft.com/downloads/d...displaylang=en
Gtk# runtime can be obtained here:
http://forge.novell.com/modules/xfmo...?gtks-inst4win
(Only the runtime is required, but if you have the .NET SDK installed I would
reccomend going for the Gtk# SDK as well.)
Alternatively you can go for Mono, just like under Linux. (See below for
details). However, I would stick to the .NET Framework, since it supports more
applications.
To run under Linux:
Install Mono and all of it's dependancies. Mono SHOULD be in your distribution's
repositories, but if it is not it can be obtained here:
http://www.mono-project.com/Downloads
And now the program:
Binary (zip):
http://www.hoojamomma.com/robotics/l...en-0.1-bin.zip
Binary (tarball):
http://www.hoojamomma.com/robotics/l...0.1-bin.tar.gz
Source (tarball):
http://www.hoojamomma.com/robotics/l...Gen-0.1.tar.gz
Also note that the binary zip and a screenshot are attached to this post.
See the README file for more details. Please try it out and tell me how you like it! (Yeah, I know, a little late in the build season for this, right? But maybe it'll help you with some last-minute changes. Those always seem to come up.)
-Rajeev Sharma
Name:	Screenshot-LUT Generator.png
Unread 14-02-2006, 16:32
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: Lookup Table Generator GUI
I don't really get it. A GUI for lookup tables? That shows graphs?
Confused,
Paul Dennis
Unread 14-02-2006, 16:51
AKA: Rajeev Sharma
Team Role: Student
Confused,
Paul Dennis
No, no graphs. Let's say that you want a lookup table for tangent (just like in the screenshot I attached). You want input values of 0-255 in increments of 1, with 0 being itself and 255 being 2pi. (This program uses radians, btw.) So your function would be:
f(x) = tan((x/255) * (2pi))
So you enter that function, click generate, and bam, there's your lookup table.
Or, just to illustrate my point, you could do this:
f(x) = x
And it would generate a lookup table of {0, 1, 2, 3, 4, ...... 0xFE, 0xFF}.
Sorry if I've been unclear, or I'm writing this too fast... I can try to explain it again if you don't understand, or you might want to download the program and play around with it a little.
Rajeev Sharma
Team 1511 Rolling Thunder
hoojamomma?
Unread 14-02-2006, 18:38
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Thanks, this is going to save me a lot of time.
Unread 15-02-2006, 21:37
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
Thumbs up Re: Lookup Table Generator GUI
Beautiful. Thank you so much, R4v3! Be my valentine!
Unread 15-02-2006, 22:10
Andrew Blair's Avatar
FRC #0306 (CRT)
Confused,
Paul Dennis
Basically, if I may elaborate, it takes a math function of any sort, and generates the applicable, integer values, in hexadecimal, into a lookup table of your choice. Eliminates syntax errors and you having to type in 5000 values by hand... Looks good! (Wishing I had this two weeks ago...)
-Sir Francis Bacon
-Albert Einstein
Unread 15-02-2006, 22:22
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Hmmm... this is cool.
Wouldn't it be neat if someone wrote a program to generate a lookup table based on a drawn graph? You could just sketch the curve, tell it how precise to be, how many entries the table should have, what the range of values should be, etc. and it would generate it. Espescially nice because you could visually tweak something. If you really want to go the extra mile, add the ability to start with a mathematical function and then drag points around.
I may just do this in the offseason...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Sortable table for use on webpages Elgin Clock Website Design/Showcase 2 22-05-2005 17:09
full table? Shlomi32 General Forum 2 27-04-2005 10:03
Table Tennis Players, Anyone PEKMAN Championship Event 0 19-04-2005 21:01
A VERY nice perl script for generating lookup tables. Validius Programming 11 31-03-2005 10:15
Lookup table generation tool WillyC Programming 12 15-02-2004 21:01
