Re: Camera isn't working
A servo is a tiny motor with a built-in position sensor, along with a small circuit that controls the motor in order to make the sensed position match the commanded position. You will need to duplicate that sort of system with a motor from the Kit of Parts and a position-sensing device such as a potentiometer, along with programming that controls the motor in order to make the sensed position match the commanded position. A simple algorithm would be to find the error between the desired and measured positions and drive the motor in the appropriate direction until the error is near zero.
For a fancier and more effective algorithm, search the forums for PID position control. |
| Who has the camera working? | cvbritton | Programming | 43 | 28-01-2007 13:46 |
| Camera shows no love to drive motors | anifinder | Programming | 4 | 13-02-2006 10:31 |
| Camera code not working.... | DemonYawgmoth | Programming | 5 | 11-02-2006 09:21 |
| Camera not working | st1nkm4n | Programming | 7 | 02-02-2006 08:22 |
| Camera stops working when we use camera_set_servos()... | SeanCassidy | Programming | 16 | 13-02-2005 03:08 |
