A few simple programming questions;
Well, First we have a few problems so I'll label them. I'll upload the code at the end, so far its all in the user_routines.c
1. I'm not sure anymore if I am programming the buttons correctly, I don't know much about C so its a good problem I'm messing up somewhere. Here is one part I am trying the buttons will do the "else" part but will not do the if part of it. I'm sure I am doing something wrong here so help is nice. if(p3_sw_top == 1) { pwm09 = 127; pwm10 = 127; } else { pwm09 = 254; pwm10 = 254; } and if(p3_sw_trig == 1) { pwm09 = 0; pwm10 = 0; } else (p3_sw_trig == 0); { pwm09 = 254; pwm10 = 254; } 2. We are using spikes this year, and I am not sure how to program them, I'm sure I have to program it somehow but I am at a lost of how to. 3. I am getting a syntax error at line 467 in our user_routines.c...The code ends at 466, before that really cause the last few lines are the from the /**/ stuff. I hope I put the code on here correctly. If not I'll edit it after I post. 4. I'm still looking but can someone tell me where to get a white paper about limit switches, this isn't something I am worrying to much about now, though. I'll just have to play with it later. Which will me create a few threads in the future most likely. Thats all, I know its a lot, but I'm the only programmer on the team and I know nothing about C. So I would really appreciate any help you guys can give me. Also sorry the code is kinda sloppy, I have been commenting things in and out adding so much stuff it makes my brain hurts. I'll also give a cookie to all who help ![]() Thanks Josh Code:
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
* This file contains the default mappings of inputs
* (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
* You can either modify this file to fit your needs, or remove it from your
* project and replace it with a modified copy.
#include <stdio.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
extern unsigned char aBreakerWasTripped;
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
/* EXAMPLES: (see MPLAB C18 User's Guide, p.9 for all types)
unsigned char wheel_revolutions = 0; (can vary from 0 to 255)
unsigned int delay_count = 7; (can vary from 0 to 65,535)
int angle_deviation = 142; (can vary from -32,768 to 32,767)
unsigned long very_big_counter = 0; (can vary from 0 to 4,294,967,295)
* FUNCTION NAME: Limit_Switch_Max
* PURPOSE: Sets a PWM value to neutral (127) if it exceeds 127 and the
* limit switch is on.
* CALLED FROM: this file
* ARGUMENTS:
* Argument Type IO Description
* switch_state unsigned char I limit switch state
* *input_value pointer O points to PWM byte value to be limited
* RETURNS: void
void Limit_Switch_Max(unsigned char switch_state, unsigned char *input_value)
if (switch_state == CLOSED)
if(*input_value > 127)
*input_value = 127;
* FUNCTION NAME: Limit_Switch_Min
* PURPOSE: Sets a PWM value to neutral (127) if it's less than 127 and the
* ARGUMENTS:
* RETURNS: void
void Limit_Switch_Min(unsigned char switch_state, unsigned char *input_value)
if(*input_value < 127)
*input_value = 127;
* FUNCTION NAME: Limit_Mix
* PURPOSE: Limits the mixed value for one joystick drive.
* CALLED FROM: Default_Routine, this file
* ARGUMENTS:
* intermediate_value int I
* RETURNS: unsigned char
unsigned char Limit_Mix (int intermediate_value)
static int limited_value;
if (intermediate_value < 2000)
limited_value = 2000;
else if (intermediate_value > 2254)
limited_value = 2254;
else
limited_value = intermediate_value;
return (unsigned char) (limited_value - 2000);
* FUNCTION NAME: User_Initialization
* PURPOSE: This routine is called first (and only once) in the Main function.
* You may modify and add to this function.
* CALLED FROM: main.c
* ARGUMENTS: none
* RETURNS: void
void User_Initialization (void)
Set_Number_of_Analog_Channels(SIXTEEN_ANALOG); /* DO NOT CHANGE! */
/* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
digital_io_01 = digital_io_02 = digital_io_03 = digital_io_04 = INPUT;
digital_io_05 = digital_io_06 = digital_io_07 = digital_io_08 = INPUT;
digital_io_09 = digital_io_10 = digital_io_11 = digital_io_12 = INPUT;
digital_io_13 = digital_io_14 = digital_io_15 = digital_io_16 = INPUT;
digital_io_18 = INPUT; /* Used for pneumatic pressure switch. */
Note: digital_io_01 = digital_io_02 = ... digital_io_04 = INPUT;
is the same as the following:
digital_io_01 = INPUT;
digital_io_02 = INPUT;
/* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
digital_io_17 = OUTPUT; /* Example - Not used in Default Code. */
/* THIRD: Initialize the values on the digital outputs. */
rc_dig_out17 = 0;
/* FOURTH: Set your initial PWM values. Neutral is 127. */
/*pwm01 = pwm02 =*/ pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
/* FIFTH: Set your PWM output types for PWM OUTPUTS 13-16.
/* Choose from these parameters for PWM 13-16 respectively: */
/* IFI_PWM - Standard IFI PWM output generated with Generate_Pwms(...) */
/* USER_CCP - User can use PWM pin as digital I/O or CCP pin. */
Setup_PWM_Output_Type(IFI_PWM,IFI_PWM,IFI_PWM,IFI_PWM);
Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin:
CCP2CON = 0x3C;
PR2 = 0xF9;
CCPR2L = 0x7F;
T2CON = 0;
T2CONbits.TMR2ON = 1;
Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
/* Add any other initialization code here. */
Putdata(&txdata); /* DO NOT CHANGE! */
Serial_Driver_Initialize();
printf("IFI 2006 User Processor Initialized ...r"); /* Optional - Print initialization message. */
User_Proc_Is_Ready(); /* DO NOT CHANGE! - last line of User_Initialization */
* FUNCTION NAME: Process_Data_From_Master_uP
* PURPOSE: Executes every 26.2ms when it gets new data from the master
* microprocessor.
* ARGUMENTS: none
* RETURNS: void
void Process_Data_From_Master_uP(void)
static unsigned char i;
Getdata(&rxdata); /* Get fresh data from the master microprocessor. */
Default_Routine(); /* Optional. See below. */
/* Add your own code here. (a printf will not be displayed when connected to the breaker panel unless a Y cable is used) */
printf("Port1 Y %3d, X %3d, Fire %d, Top %dr",pwm01,pwm05,p1_sw_trig,p1_sw_top); /* printf EXAMPLE */
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
/* Example code to check if a breaker was ever tripped. */
if (aBreakerWasTripped)
for (i=1;i<29;i++)
if (Breaker_Tripped(i))
User_Byte1 = i; /* Update the last breaker tripped on User_Byte1 (to demonstrate the use of a user byte)
Normally, you do something else if a breaker got tripped (ex: limit a PWM output) */
* FUNCTION NAME: Default_Routine
* PURPOSE: Performs the default mappings of inputs to outputs for the
* Robot Controller.
* CALLED FROM: this file, Process_Data_From_Master_uP routine
* ARGUMENTS: none
* RETURNS: void
void Default_Routine(void)
/*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
* This maps the joystick axes to specific PWM outputs.
pwm01 = p1_y; ORIGANAL STUFF
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
/*pwm01;*/
/*pwm02;*/
/*pwm03; */ /*cmucam power*/
/*pwm04; */ /*none*/
/*pwm05;*/ /*solenoid-plate*/
/*pwm06;*/ /*door-bush-1 on/off fwd/off-2 on/off rev if rev then pw 11/12 off*/
/* if(p3_sw_aux1 == 1)
pwm06 = 0;
else if(p3_sw_aux1 == 0)
pwm06 = 254; /*
/*pwm07;*/ /*globe H pan r/l*/
pwm07 = p3_x;
/*pwm08;*/ /*globe V tilt u/d*/
pwm08 = p3_y;
/*pwm09 = pwm10;*/ /*MB shoot* 1/2*/
if(p3_sw_trig)
/*if(p3_sw_trig == 1)
pwm09 = 0;
pwm10 = 0;
/* else (p3_sw_trig == 0);
pwm09 = 254;
pwm10 = 254;
/*window r on/off*/
/*pwm11 = pwm12; */ /*window l on/off*/
if(p3_sw_top == 1)
pwm09 = 127;
pwm10 = 127;
else
pwm09 = 254;
pwm10 = 254;
if(p4_sw_trig == 1)
pwm05 = 127; /*else if statement after*/
pwm06 = 127;
pwm07 = 127;
pwm08 = 127;
pwm09 = 127;
pwm10 = 127;
pwm11 = 127;
pwm12 = 127;
/*---------- 2 Joystick Drive ----------------------------------------------
* This code mixes the Y and X axis on Port 1 to allow one joystick drive.
* Joystick forward = Robot forward
* Joystick backward = Robot backward
* Joystick right = Robot rotates right
* Joystick left = Robot rotates left
* Connect the right drive motors to PWM13 and/or PWM14 on the RC.
* Connect the left drive motors to PWM15 and/or PWM16 on the RC.
pwm13 = 254 - p2_y;
pwm14 = 254 - p2_y;
pwm15 = p1_y;
pwm16 = p1_y;
if((pwm13>118)&&(pwm13<136)) pwm13 = 127;
if((pwm14>118)&&(pwm14<136)) pwm14 = 127;
if((pwm15>118)&&(pwm15<136)) pwm15 = 127;
if((pwm16>118)&&(pwm16<136)) pwm16 = 127;
/*if((pwm03>145)) pwm03 = 255;
if((pwm03<109)) pwm03 = 0;*/ /*old robot arm*/
/*if((pwm13>189)) pwm13 = 230;pwm13
if((pwm14>189)) pwm14 = 230;
if((pwm15>189)) pwm15 = 230;
if((pwm16>189)) pwm16 = 230;
if((pwm13<65)) pwm13 = 25;
if((pwm14<65)) pwm14 = 25;
if((pwm15<65)) pwm15 = 25;
if((pwm16<65)) pwm16 = 25; */
orange = banana
undefened int = orange
undefened int = banana
if((orange>129)){orange = 254};
if((orange>120)&&(orange<134)) orange = 127;
else if((orange>=0)&&(orange<=120))orange=0;
else((orange>=134)&&(orange<=254)) orange=254;
/*---------- Buttons to Relays----------------------------------------------
* This default code maps the joystick buttons to specific relay outputs.
* Relays 1 and 2 use limit switches to stop the movement in one direction.
* The & used below is the C symbol for AND
/* relay1_fwd = p1_sw_trig & rc_dig_in01; /* FWD only if switch1 is not closed. */
/* relay1_rev = p1_sw_top & rc_dig_in02; /* REV only if switch2 is not closed. */
/* relay2_fwd = p2_sw_trig & rc_dig_in03; /* FWD only if switch3 is not closed. */
/* relay2_rev = p2_sw_top & rc_dig_in04; /* REV only if switch4 is not closed. */
relay3_fwd = p3_sw_trig;
relay3_rev = p3_sw_top;
relay4_fwd = p4_sw_trig;
relay4_rev = p4_sw_top;
relay5_fwd = p1_sw_aux1;
relay5_rev = p1_sw_aux2;
relay6_fwd = p3_sw_aux1;
relay6_rev = p3_sw_aux2;
relay7_fwd = p4_sw_aux1;
/*relay7_rev = p4_sw_aux2; */
/*relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
/* relay8_rev = 0;
/*---------- PWM outputs Limited by Limit Switches ------------------------*/
Limit_Switch_Max(rc_dig_in05, &pwm03);
Limit_Switch_Min(rc_dig_in06, &pwm03);
Limit_Switch_Max(rc_dig_in07, &pwm04);
Limit_Switch_Min(rc_dig_in08, &pwm04);
Limit_Switch_Max(rc_dig_in09, &pwm09);
Limit_Switch_Min(rc_dig_in10, &pwm09);
Limit_Switch_Max(rc_dig_in11, &pwm10);
Limit_Switch_Min(rc_dig_in12, &pwm10);
Limit_Switch_Max(rc_dig_in13, &pwm11);
Limit_Switch_Min(rc_dig_in14, &pwm11);
Limit_Switch_Max(rc_dig_in15, &pwm12);
Limit_Switch_Min(rc_dig_in16, &pwm12);
/*---------- ROBOT FEEDBACK LEDs------------------------------------------------
* This section drives the "ROBOT FEEDBACK" lights on the Operator Interface.
* The lights are green for joystick forward and red for joystick reverse.
* Both red and green are on when the joystick is centered. Use the
* trim tabs on the joystick to adjust the center.
* These may be changed for any use that the user desires.
if (user_display_mode == 0) /* User Mode is Off */
{ /* Check position of Port 1 Joystick */
if (p1_y >= 0 && p1_y <= 56)
{ /* Joystick is in full reverse position */
Pwm1_green = 0; /* Turn PWM1 green LED - OFF */
Pwm1_red = 1; /* Turn PWM1 red LED - ON */
else if (p1_y >= 125 && p1_y <= 129)
{ /* Joystick is in neutral position */
Pwm1_green = 1; /* Turn PWM1 green LED - ON */
else if (p1_y >= 216 && p1_y <= 255)
{ /* Joystick is in full forward position*/
Pwm1_red = 0; /* Turn PWM1 red LED - OFF */
else
{ /* In either forward or reverse position */
} /*END Check position of Port 1 Joystick
/* Check position of Port 2 Y Joystick
(or Port 1 X in Single Joystick Drive Mode) */
if (p2_y >= 0 && p2_y <= 56)
Pwm2_green = 0; /* Turn pwm2 green LED - OFF */
Pwm2_red = 1; /* Turn pwm2 red LED - ON */
else if (p2_y >= 125 && p2_y <= 129)
Pwm2_green = 1; /* Turn PWM2 green LED - ON */
Pwm2_red = 1; /* Turn PWM2 red LED - ON */
else if (p2_y >= 216 && p2_y <= 255)
{ /* Joystick is in full forward position */
Pwm2_red = 0; /* Turn PWM2 red LED - OFF */
else
Pwm2_green = 0; /* Turn PWM2 green LED - OFF */
} /* END Check position of Port 2 Joystick */
/* This drives the Relay 1 and Relay 2 "Robot Feedback" lights on the OI. */
Relay1_green = relay1_fwd; /* LED is ON when Relay 1 is FWD */
Relay1_red = relay1_rev; /* LED is ON when Relay 1 is REV */
Relay2_green = relay2_fwd; /* LED is ON when Relay 2 is FWD */
Relay2_red = relay2_rev; /* LED is ON when Relay 2 is REV */
Switch1_LED = !(int)rc_dig_in01;
Switch2_LED = !(int)rc_dig_in02;
Switch3_LED = !(int)rc_dig_in03;
} /* (user_display_mode = 0) (User Mode is Off) */
else /* User Mode is On - displays data in OI 4-digit display*/
User_Mode_byte = backup_voltage*10; /* so that decimal doesn't get truncated. */
} /* END Default_Routine(); */
| How To Ask Questions the Smart Way | Brandon Martus | General Forum | 8 | 27-03-2013 15:52 |
| Programming laptops | [527]phil | Programming | 24 | 22-08-2005 12:28 |
| #1 The Journey of a FIRST Graduate: Questions | Ken Leung | General Forum | 12 | 27-07-2005 18:24 |
| Suggestion for Delphi Programming Posts | Chris Hibner | CD Forum Support | 1 | 27-07-2005 10:02 |
| Can You help us??? (programming questions) | HuskieRobotics | Programming | 1 | 24-02-2004 21:19 |
