Go to Post Paper is not so bad. It is really rare for it to crash or run out of battery, for example... - DonRotolo [more]
Unread 10-02-2006, 09:49
scottmso scottmso is offline
FRC #1561 (RoboDucks)
scottmso is an unknown quantity at this point
Send a message via AIM to scottmso
Math functionality in EasyC?
I'm trying to see if I can design a function to help calculate a trajectory for our robot. Does EasyC have the math libraries that I would need to do this such as sin, cos, and tan? The other programmers didn't want to learn C this year (even though they had the opportunity) and seem to want to use EasyC but I would personally rather program it in regular C (MPLAB) especially if I will need to use it for what I want to do. Thanks
Unread 11-02-2006, 08:16
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Math functionality in EasyC?
You can get all the standard math libraries which are described in the Microchip C18 Users Guide. To do this and not get compiler errors you must include <math.h> which can be done from the "File inclusion" dialog on the Options menu. Make sure to include the <> as part of the file name.
Brad Miller
Robotics Resource Center
Unread 14-02-2006, 17:29
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
Where should we place the math.h file?
Unread 14-02-2006, 17:36
Tobaby817's Avatar
Tobaby817 Tobaby817 is offline
RoboCoach/Designer Extraordinare
AKA: Toby
FRC #1396 (Pyrobots)
Tobaby817 is an unknown quantity at this point
Send a message via AIM to Tobaby817
in the file where you use the mathematical functions. #includes are only useful for the file you put them in
"If at FIRST you don't succeed, you're probably on Team 1396"
--Washers are for women--
Unread 14-02-2006, 21:11
intelitek_Chris intelitek_Chris is offline
intelitek_Chris will become famous soon enoughintelitek_Chris will become famous soon enough
The math header file is already included in the compiler. All you need to do is go to the File Inclusion Window in the options menu, and type in:
<math.h>
Then you will have access to the functions provided by that header file, such as sin, cos, tan, etc.
Unread 16-02-2006, 09:59
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
after I include the file I wiil be able to see it like that : #include <sdsdsd>
Or it will automaticlly put it in the main.h ?
Unread 16-02-2006, 11:19
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
Give it a try, just don't forget that math.h uses radians to measure angles.
Unread 16-02-2006, 14:52
AKA: Brad
The actual include declaration gets inserted into the Main.h file as you said and the Main.h file is included in all the other files you create.
The only way to see it is to look at the "Project" tab on the left hand window. Then you can select Main.h and see the includes.
Brad Miller
Math in careers EricH Career 40 24-06-2008 21:45
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
