Go to Post 1 alliance wins a given tournament but all teams teams have a chance to define, chart, and create their own success. - PayneTrain [more]
Unread 14-02-2006, 22:55
Re: A few simple programming questions;
and
is that a line of code or only a comment in your post?
Im almost certain there is no IF AND ELSE statement ?
Unread 15-02-2006, 00:13
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
You are correct. A search shows that syntax was not used in his code.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 15-02-2006, 09:45
I see you have an unmatched bracket here that will give you the syntax error.
if(p3_sw_trig)
My main suggestion would be to change how you are commenting out lines and blocks of code.
Switch over to the // form rather than use the /* */ form.
Your blocks are ending in random places.
Unread 15-02-2006, 10:50
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
if(p3_sw_trig)
You're absolutely right, Mark. The problem is that the code is poorly written. IE, the original code that they gave us. Whoever writes the code apparently hasn't come to the realization that C++ style comments (//like this) are available in C now. It used to be that /*this*/ was all there was. However, it's bad coding practice to write one liners like this:
complicatedMethod(); /*Some comment here*/
Because if you want to block comment that line and a bunch of other like it, you will not be able to easily because the */ at the end will also end yours! The easiest way I have found around this without bothering to change the code (i.e. change /**/ to //) is to use this:
#if 0
complicatedMethod1(); /*Some comment here*/
complicatedMethod2(); /*Some comment here*/
complicatedMethod3(); /*Some comment here*/
#endif
Alright, that's all for now folks. I think cruella wants to make a coat out of my posts.
Paul Dennis
Unread 15-02-2006, 11:49
I agree, it should be no IF, AND, or BUT statements.
How To Ask Questions the Smart Way Brandon Martus General Forum 8 27-03-2013 15:52
Programming laptops [527]phil Programming 24 22-08-2005 12:28
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Can You help us??? (programming questions) HuskieRobotics Programming 1 24-02-2004 21:19
