Go to Post Brainstorming and creativity are great, but you do actually have to build the ideas you come up with sometime. - Chris is me [more]
Unread 14-02-2006, 21:59
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Wires Pull Themselves Out
We have our camera working, but we have the problem of the PWM cables (specifically the TTL one) pulling themselves out. Any suggestions on wiring that might prevent this? Thanks!
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 14-02-2006, 23:06
Re: Wires Pull Themselves Out
find a place to tie-wrap the wire to something right next to the camera. The connectors are not designed to hold the weight of the cable.
those little tiewrap foam tape stick on square anchor things work great
Unread 14-02-2006, 23:14
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Hot glue gun is what we use. We hot glue EVERYTHING. PWM cables on robot controller, Victors, relays, digital I/O, analog, CMUCAMERA.....everything...
And you can remove it pretty easy afterwards if you need to.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 14-02-2006, 23:58
I have a hot melt glue gun and I'm not afraid to use it. But. Would you like to share exactly how you apply it?
Unread 15-02-2006, 07:50
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Im not sure exactly ho but I would guess, you would plug the PWM in. Then apply it in the crack of the victor and the pwm. Around the outside edge.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 15-02-2006, 07:52
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
On the side of the mount there are holes, I removed the plastic casing from around the wires, pushed it through, and stuck them back in the plastic casing. Then I placed it on the board. This means they get less movement at where they are attached at the board, thus meaning they don't fall out. Then to the computer, I have it attached along the way with a tie-wrap from where the camera is positioned, so it should not fall out, if it does we have a serious problem.
Since mine is tilt only these days, I don't really have to worry about the pan causing tension, as the tilt amount is not enough to get it the cable to accidently fall out.
Hot gluing anything is not what I would suggest, but if it works for you, good luck with it.
My Blog!
Unread 15-02-2006, 13:39
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Hot glue is actually an industry standard solution (as explained to me by an electrical engineer; it has excellent insulating properties).
If you take apart a radio, TV, etc. sometimes you will find hot glue holding vibration-sensitive parts onto the board.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 15-02-2006, 13:44
I dont know if its PC or even GP to come out and say this on a public forum,
but.... a robot that likes to pull out its own wires? We frown on that around here!
Your robot needs professional help! :^)
Unread 15-02-2006, 18:35
AKA: Bert JW Regeer
When I over the course of one summer worked at Philips the Dutch company, we were told not to use hot glue, as it can accidently melt wires, instead we were using some extremely strong tape.
My Blog!
Unread 15-02-2006, 18:48
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
It is possible, if the gun nozzle were to touch the wire directly but the glue itself shouldn't be hot enough to sheathing. At most you can only get a light burn from hot glue and it cools almost instantly. The only thing that is a negative here is that if you need to move electronics or replacing wires, and you often do, you might find that your wires are glued to your robot (who would have thought) While your at it secure down all the PWMs any one of them get pulled, and PWMs have a bad habit of this, and you might lose function of a vital piece of your robot. Zip ties work great and if you don't have a place to mount them the sticky pads are perfect.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 15-02-2006, 21:03
AKA: Steve
The only problem is that tape is illegal in FIRST unless it is used as an insulator.
Unread 15-02-2006, 21:12
Andrew Blair's Avatar
FRC #0306 (CRT)
Hmmm. There are low temp melt hot glues; I wonder if that's what they were referring to? MechanicalBrain is right in that is is rather hard, without touching the tip, to get a bad burn from hot glue. We havn't done it in a few years, but it seemed to work very well when we did.
-Sir Francis Bacon
-Albert Einstein
Unread 22-02-2006, 14:54
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
Yeah, say that hot glue doesn't burn to the scar on my left hand that I've had since fifth grade.
Unread 22-02-2006, 19:41
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
One of our mentors gets this orange anti-tamper stuff from his job.. We've used that for most of our robots, and never had a problem with it.
Unread 22-02-2006, 20:02
AKA: Dr. Brooks
no team (WRRF)
These connectors were enough of a disaster that I did not trust them.
We cut the plastic casing off and carefully soldered the wires onto
the formerly encased connectors, then insulated them. On the power
wiring we actually pulled the connector pins, but had so much trouble
getting the solder out of the plated through holes we did not try that
again. Once the solder was out of the plated through holes, however,
you get a really good soldering job for the cabling directly to the board.
Eugene
Blue Drill Motor wires? j_pannell Electrical 4 17-02-2004 15:06
update 8 clarification, drill motor and blue wires pryoplasm Rules/Strategy 23 13-02-2004 07:26
What gauge wires Punjabguy87 Electrical 7 07-02-2004 20:25
extra 40amp wires Lord Nerdlinger Electrical 4 14-02-2003 14:53
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
