| View Poll Results: How far are you on your robot? | |||
| 90-100% |
32 | 28.83% |
| 80-89% |
22 | 19.82% |
| 70-79% |
19 | 17.12% |
| 60-69% |
23 | 20.72% |
| 50-59% |
7 | 6.31% |
| 40-49% |
3 | 2.70% |
| 30-39% |
1 | 0.90% |
| 20-29% |
1 | 0.90% |
| 10-19% |
1 | 0.90% |
| 0-9% |
0 | 0% |
| who ever said anything about starting?!?! |
2 | 1.80% |
| Voters: 111. You may not vote on this poll | |||
Re: How Close are you to done?
Machining and welding should be wrapping up tomorrow night. Then, we have to assembly and wire everything.
EDIT. omg, we're screwed. I just found out that our gears were machined wrong, and the shifting dogs won't fit in as lossely as they should. This is bad. EDIT2. with a little filing, a little grease, and a little more air pressure, it should be okay. And the programmers will enjoy the minimized backlash. Last edited by sanddrag : 15-02-2006 at 01:49. |
Its definitly an advantage to the team when your school has a state of the art welding and machining lab, a cad lab with a 3D printer, and students who know how to utilize the equiptment, and teachers who believe in FIRST. it makes meeting ship date much easier, and your robot more efficient.
I suspect we will finish on Sunday...
90-100, building the robot only needed some last twiking and the shielding for our firing mechanism
programing is at 10% though, they got the cannon working and the robot drives (sort of) but no autonemous, I hope they make it, they start their work tomorrow |
Being done is a state of mind which only occurs after winning nationals...But we're close to finishing the robot, everything is designed and most is already assembled into sub-components but its the putting everything together part, probably finished sat night or sunday after we make sure it'll meet weight
#7
1023 is coming along. We have our unveiling tonight and plan to spend the rest of the season practicing, programming, and fine tuning. We set last Sunday as the last day for any major changes to the robot. We are just under weight and things are looking pretty good, assuming nothing breaks.
#8
O and were about 70-80% done, we have our shooter on 2 out of 3 gearboxes built, and all we really need to do now is get our hopper welded on along with our ball collector Last edited by CaseyKasem_1251 : 15-02-2006 at 09:41. |
#9
If you are at BAE or Boston this year, you will see us in action.Last edited by Daniel Morse : 15-02-2006 at 21:28. |
#11
| Close center cap in Auto | JohnBoucher | Regional Competitions | 10 | 04-04-2005 18:42 |
| when do the nominations close | king_moleman | Unsung FIRST Heroes | 1 | 26-04-2004 15:27 |
| When the regional is close to home | Alfred Thompson | Regional Competitions | 8 | 17-12-2002 13:39 |
| Woah so close.... | archiver | 2001 | 1 | 24-06-2002 03:01 |
| So close, but not close enough | archiver | 2001 | 1 | 23-06-2002 23:45 |
