Go to Post The purpose of this forum is for us to communicate our ideas, so that we can collectively strengthen our ability to inspire others. - Jaine Perotti [more]
Unread 14-02-2006, 01:09
tpc's Avatar
tpc tpc is offline
AKA: Tom Convery
FRC #0623 (Cougar Robotics)
tpc is on a distinguished road
Attaching LED's to OI joystick ports?
Hi all,
Has anyone attached LED's to the OI's joystick ports? Page 5 of the OI reference guide seems to indicate that I can attach LED's directly to the joystick port pins, without needing to put a resistor in series. Can anyone confirm that this is true? (I'd like to avoid turning any LED's into DED's (dark emitting diodes) if possible. )
Thanks!
-tpc
Unread 14-02-2006, 07:41
Re: Attaching LED's to OI joystick ports?
Confirmed. You get no more than 10 milliamps out of the LED driver pins, which will safely light one LED without destroying it.
Unread 15-02-2006, 00:28
tpc's Avatar
tpc tpc is offline
AKA: Tom Convery
I tried it this afternoon and it worked like a charm. No DED's.
Thanks!
Unread 15-02-2006, 00:46
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Is there a way to have them controlled by robot feedback? Like how the feedback LED's on the OI are, but plugged into a joystick port pin so we can have them somewhere else on the controller....
Unread 15-02-2006, 06:51
That's exactly what the OI's LED outputs are. They duplicate the state of the pwm and relay LEDs.
Unread 15-02-2006, 08:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I have not confirmed this but I believe that the OI has an internal LED driver of 10mA (something like the STP16C596 perhaps).
The nice thing about constant current LED drivers is that they provide 10mA regardless of the LED's internal voltage drop, resistance, etc. You can test this out by stacking 2 LED's series. If 2 LED's in series still pull 10mA just like the 1 LED does, then odds are IFI isn't just using an internal resistor to limit current.
Joe J.
Team #88, TJ2
Unread 15-02-2006, 08:19
tpc's Avatar
tpc tpc is offline
AKA: Tom Convery
See http://ifirobotics.com/docs/oi-ref-guide-11-21-05.pdf pp. 7 & 9 for the details.
-tpc
Joystick Ports as Duplex Data Port zachriggle Control System 9 07-02-2006 18:19
Free programming help Cuog Programming 24 24-01-2006 16:43
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
