Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Unread 15-02-2006, 07:49
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
Circuit Breaker Panel
I believe that our team was given the wrong breaker panel. We got a much smaller panel with only 6 ports and another with either 10 or 12. The 40 amp-fuses don't fit anywhere. considering that we did not notice this until the final week, there is nothing we can do about it. i was wondering if we can use 30 amp fuses for the CIM motors? the faster i can find out this information the better. please help.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 15-02-2006, 07:58
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
Re: Circuit Breaker Panel
If you look at the IFI power distribution diagram, the 40amp loads go through a gold-ish block that caters to four motors and a black power distribution block (I think these terms are correct.. ). My team is using 5 CIMS, not 4, so we decided to buy the 2005 breaker panel that can hold 6 40amp loads instead of just 4 (it lookes much easier to wire, too).
I recommend AGAINST hooking up any of the 40amp loads to 30amp fuses.
So, if you have 5 or more CIMS, I suggest you rush order the 2005 breaker panel from IFI. If you have 4 or fewer, take a good look at the power distribution diagram in the FIRST manual and wire accordingly.
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
Unread 15-02-2006, 09:05
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Erin, what motors are you using? Because if you are using 4 CIM motors you are in violation of <R43>. Unless at least one of your "CIM motors" is a "Fisher Price CIM motor."
Unread 15-02-2006, 10:23
Paco,
You can run the chalupas from 30 amp breakers using the small fuse blocks and the appropriate sized wire but... As Erin pointed out, you wouldn't want to make that decision on a drive motor, you need all the protection you can get.
In order to use the 40 amp breakers you must use the four position Maxi block and the distribution block for the common returns to feed speed controllers, per the robot electrical drawing and robot rules.
Unread 15-02-2006, 12:17
General Manager
4 small CIMS for drive and 1 big Fisher Price CIM for something else. I clumped them together because they're all 40amp loads.
Unread 15-02-2006, 15:49
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
I hope not, because we are running 4 CIMs in our drivetrain.
<R43> Specific items allowed include:
• Additional HITEC HS-322HD Servos.
• Teams may utilize one or two additional small CIM motors (part #FR801-001) in addition to those provided in the kit of parts. This means that you may use up to four, and no more, small CIM motors on the robot.
Old Breaker Panel vector023 Electrical 4 31-01-2006 16:55
New Model Posted - 2005 Breaker Panel Ed Sparks Inventor 5 01-01-2006 23:25
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
Breaker Panel Gal Longin Electrical 1 13-01-2005 16:01
circuit breaker archiver 2001 2 23-06-2002 23:18
