Go to Post Brandon, your amazing! CD media will rock my socks off more then DS&K! :p Ok, maybe I won't go that far. - Kyle Love [more]
Unread 15-02-2006, 10:42
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: A few simple programming questions;
Originally Posted by Inverted
Sorry I'm not being as big of a help as I should be, but I'm in the middle of homework and just answering the questions where the solution is on the top of my head.
You don't need (p3_sw_trig == 0) after the else, it's already implied. Also, (this may be wrong because I haven't written code like this in 2 years) I think you only need one = when referring to the value of the button, not ==.
The PWM cable from the Spike goes into one of the Relay outputs on the robot controller. Then you just map which buttons you want to control which relays and you're good. Not sure if you know how to or not, but send me a PM if you want to know how to have one button control the in/out of a piston and such (like if you want a solenoid to act like a festo).
Technically, it's not implied. The code within the segment following the else executes no matter what if the first IF and all IF ELSEs after it fail.
Another correction: == is an operator that returns a one or a zero based on whether the LHS (left hand side) is equal to the RHS. the = operator sets the LHS (which has to be a valid LHS, aka a variable) equal to the RHS. It returns the set value. C will let you get away with this:
if (x = 5)
stuff();
It assumes, "Oh, I know what he wants to do. He wants me to set x to five and then check to see if x or not." AKA, this will not cause a compile time error, whereas in Java it will.
Note that the == returns a 1 or a 0, not any boolean value, for those used to Java or other such. The other comparisons (>, < , <=, >=, etc) work the same way.
Neat but terrible shorthand (don't do this):
x += x < 100;
Which does? I throw it out there.
Paul Dennis
Unread 15-02-2006, 11:42
x += x < 100;
Ooh, clever. Dangerous, but clever. It increments x unless it's already 100 or greater.
if (x < 100)
    x = x + 1;
It's true, C does give you enough rope to shoot yourself in the foot.
Unread 15-02-2006, 19:27
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
if (x < 100)
    x = x + 1;
Yes it does. I came up with this one myself... a very interesting mix of metaphors there. I would use the ++ but it's all semantic.
But there is absolutely no reason to do this. It doesn't save you any time, and it doesn't save you an space in memory. However, there is, and I kid you not, a contest to obfuscate code. This is a fairly simple example of that.
Paul Dennis
Unread 15-02-2006, 20:11
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
I've seen bugs introduced when people use pre or post ++ at the wrong time.
Paul Dennis
I agree with you on making code readable. Years ago I encountered a line of code written by a guy -- it was doing some sort of math but had around 10 different operators in one line including bit and math operators and was impossible to understand. And this was in production software that a team of people had to maintain.
Even something as simple as always using parentheses to establish precendence instead of relying on operator precendence makes code much more understandable.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 15-02-2006, 21:16
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
An example? I'm curious.
Some people think that there is somehow an advantage to cramming something into the fewest lines possible (ahem!). Sometimes it's necessary to optimize things even if these optimizations make things less readable. If your program does billions of mod 32 calculations, and you have some method
int mod32(int x)
     while (x > 32)
            x -= 32;
     return x;
This works and everyone should be able to tell what it does. I think there's also a modulus method in the C libraries, but I could be wrong. Anyway, the point is that this would probably be a fairly clear way of doing it. But if you were trying to reduce the amount of time your program takes (and it could take a while if you enter in large numbers and do millions of calculations) this is what you would want the method to do:
int mod32(x)
     return x & 31;
It's less understandable. Some people may not even know what the & operator does. An italisized description follows:
The & is a bitwise AND operation. In other words, it works with the ones and the zeroes. AND evaluates to true or one if cond1 and cond2 evaluate to one. Example: 7&11
7 = 4+2+1;
11 = 8+2+1;
0111
1011
____
0011
The bitwise operation works faster. It only works with powers of two (don't try x&10) but in those cases, it works. If you want, think about why (or PM me). Just draw it out.
However, oftentimes the best code for processing time is the most understandable too. Also, when you think about the speed of today's processors, unless you are writing code that /needs/ to run fast, there is not much point in optimizing.
[\END LECTURE]
That was rather off-topic, but I found it interesting. I hope you did too (or skipped over it).
Tat's all for now, folks. Tit for tat.
Paul Dennis
Unread 16-02-2006, 18:01
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
Wow, Thanks for all the help. Although that last post hurts my head. But now, I think I have everything working. We are hooking up electronics now so I haven't been able to test anything, yet. But still, I'd give you all hugs, If I could, and a cookie if I could!
Danke!!!
Team 1555's only poor little programmer.
How To Ask Questions the Smart Way Brandon Martus General Forum 8 27-03-2013 15:52
Programming laptops [527]phil Programming 24 22-08-2005 12:28
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Can You help us??? (programming questions) HuskieRobotics Programming 1 24-02-2004 21:19
