Re: Magic Smoke and Shrapnel
Josh |
with all the spinning wheel shooters this year, some with variable angles, Im thinking about the steam generator station in Buffalo, along the Niagara River (near Strawberry Island).
Many years ago one of the 12 foot diameter generator armatures broke loose from its bearings. Since it was mounted vertically it bounced around the inside of the brick building for several seconds, like a giant top gone wild. Finally it hit something solid and flew out through the brick wall, landing in the niagara river a few hundred yards away. You can still see the patch where the hole in the brick wall was repaired. So what will happen if one of these spinning shooter wheels breaks loose inside a robot? It would be like a metal tornado inside the machine! |
I would hope teams to the time to properly balance their high speed wheels to minimize the vibrations that would tear apart machines. Also I woupld hope people properly use Loctite, lock nuts, lock washers, and jamb nuts to prevent things from coming apart. Hopefully we don't need to resort to safety wire.
I do believe though that I will detect the oh too familiar scent of FP magic smoke very quickly as someone will stall them or have improper air flow kill one at the regionals I attend. |
Yesturday we were testing the camera on the robot and we were running our shooting mechanism and the camera lens flew off the board and shot across the room ...It wasn't damaged but what a close call...
I love the smell of magic smoke in the morning!
I figure balls will be flying in to the crowd all the time, just from driver error... or will the crowd be made to sit further away this year? |
Our chain came apart
![]() We were running it at 4000 RMP, and the cnain hit a peice of lexan just right so it unclipped the masterlink... That was scary ![]() |
#7
I missed that, Cody, when did it happen?
#8
When you were at district jazz, I think.
#9
no double posting kids....lol
#10
In the words of one of the students as he was working with our launcher prototype, "The real surprise came when it bounced off my face." He wasn't referring to the ball, by the way.
Make sure your screws and bolts are tight, boys and girls! Oh, and we got magic(k? Aleister Crowley lives again?) smoke from our joysticks earlier. That was interesting. |
#11
Wait. Um. Shoot. |
#12
We did get a little magic smoke this year--apparently Victors don't like having the battery wired to the motor side.
At least we had some fun pulling it apart and looking at the damage. |
#13
Yeah, make sure that youre running your Victor's for any spinwheels in Coast mode. Trying to brake them can cause some bad results if they're still spinning too fast. At least for our team, that helps.
Make sure your shooters are well enclosed too. |
#14
if the Victors can spin a motor up, it should be able to coast or brake it in fact you should be able to spin the shooter up to full speed, then throw it into full reverse (to stop it) without hurting the victors. But then again, maybe the shooter wheels being built this year are using them in ways they have never been used before? If you blow one out using it this way I would definately send it back to IFI for failure analysis. And if we start seeing a lot of victors fail on shooter wheels, it would be useful to instrument one and see how much voltage and current it is seeing when it brakes the motor. Last edited by KenWittlief : 16-02-2006 at 15:38. |
#15
your robot would have an out-of-body experience Last edited by KenWittlief : 15-02-2006 at 20:51. |
