Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 15-02-2006, 15:46
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Question pneumatic programming
hi, my team is having some problems using pneumatics, and we can't seem to figure out what the problem is. The problem is that we can only shift or fire the pistons in one direction. here is my code:
if (p1_sw_trig == 1)
relay1_fwd = 1;
relay1_rev = 0;
else if (p1_sw_top == 1)
relay1_fwd = 0;
relay1_rev = 1;
else
that's all there is to the code for shifting. The thing is, if we start the piston in the retracted position, we can click the trigger on port one to fire it. however pressing port one to return it to the old position won't do anything. we're also having this one-directional problem with another piston used in our launching mechanism. Pressing both buttons on the joystick one cause the bot to make a clicking sound on one of the elctronic devices, but nothing happens. Do you know anything about what could cause this? Most of our problems arise from my programming errors hehe; but it doesn't seem feasible that is the problem in this case. could it be a wiring problem we're not aware of? thanks a bunch
-Team Lugnut (1008)
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming Forum Warning Brandon Martus Announcements 10 29-12-2005 13:32
Organizing a programming team. scitobor 617 Programming 7 28-01-2005 19:18
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
