Go to Post Why do things the easy way when you can do it with a robot? - MissInformation [more]
Unread 15-02-2006, 16:53
RC randomly resets or goes into program mode
As the topic says, our RC randomly resets or goes into program mode. I was able to isolate the problem to a group of printf()'s executing every program loop, but it seems to be happening again even with those gone.
We are running Timer 2 to run the ADC (only channel is a 50Hz sampling gyro), Timer 3 for an ultrasonic range finder, and 3 hardware interrupts (2 128ppr encoders and the range finder)
Any ideas? It may be our code is taking too long to execute, but I was under the impression the master processor would totally shut down the system if this happened. And even if that happened, what would cause program mode to trigger?
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
