Go to Post Man, I never thought I'd have to cite a rule during the offseason. - Karibou [more]
Unread 15-02-2006, 18:27
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
Re: Problem with gyro...
I think my point was that you would only need to recover if you were shooting in the center goal. And as I said, you'd be using the cam to recover. So where does the gyro come into this, I ask?
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 15-02-2006, 18:35
There are six robots on the field.
To maximize the distance measuring precision of the camera it needs to be mounted low on the robot.
Its very likely that your bots view of the target light will be blocked from time to time.
With the gyros and accelerometers you can design an inertial guidance system that cannot be blocked or inhibited by any other objects on the field.
The more senses (sensors) you robot uses the better it will be able to perform over a wide range of variables, most of which are out of your control. Once auton starts you dont know what the other 5 robots on the field are going to do.
Unread 16-02-2006, 15:17
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
So... my gyro is better connected now, but the only value that i can get is 0
what's this?
Ignore alien orders.
Unread 16-02-2006, 15:42
first step would be to put a volt meter on the output of the gyro, to see if the problem is sensor, electrical, or a SW issue.
next step is to make sure the signal is present on the input pin of the RC.
Unread 16-02-2006, 17:06
capenga's Avatar
Penga boy
AKA: Giovane
look... i've verified all the possible connections of the gyro with a volt meter, and i'm sure that all the connections are fine, and the signal arrives on the RC.
i think that the sensor's PIC is toasted
Unread 16-02-2006, 19:07
I dont know if anyone has tried to repair a failed gyro sensor. You might be better off getting one shipped overnight to you from IFI.
If you have the right power supply voltage going to the gyro board, and the output stays at 2.5 V when you turn the board on its axis of rotation, then yes, the gyro board has definately failed.
Unread 16-02-2006, 19:25
capenga's Avatar
Penga boy
AKA: Giovane
well, i don't think that ordering another sensor would be a good idea...
i'm in Brazil
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyro not accurate - Problem naor52 Programming 15 27-01-2006 16:50
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
