#14
Re: Camera isn't working
Well, if you get the pot's installed, then you won't need limit switches, as they should be able to tell you how far you have rotated and in which direction. The pot's themselves get connected to the analog inputs, and I believe you need to use something like Get_Analog_Value to actually get sensible data from them. I can't check right now, because I just shut down the computer with all my code on it.
If you do a search for pot's, you should be able to find more detailed help on them |
| Who has the camera working? | cvbritton | Programming | 43 | 28-01-2007 13:46 |
| Camera shows no love to drive motors | anifinder | Programming | 4 | 13-02-2006 10:31 |
| Camera code not working.... | DemonYawgmoth | Programming | 5 | 11-02-2006 09:21 |
| Camera not working | st1nkm4n | Programming | 7 | 02-02-2006 08:22 |
| Camera stops working when we use camera_set_servos()... | SeanCassidy | Programming | 16 | 13-02-2005 03:08 |
