Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 15-02-2006, 19:58
smarcus88 smarcus88 is offline
FRC #1888
smarcus88 is an unknown quantity at this point
Shipping Crates
Hi I am a rookie, I was just interested to see how everyone built their shipping crates,
how they mount their robot inside, and what they send in it (besides batteries and robot) and also, if any how they organize storage inside (i.e. shelves, etc)
I tried searching to see if their was a post about this and I have seen MOEmentums paper, so I apologize if I am recreating another thread. but any help from some veteran teams would be great
Unread 15-02-2006, 20:11
FlyingDutchman FlyingDutchman is offline
FRC #1566
FlyingDutchman will become famous soon enoughFlyingDutchman will become famous soon enough
Re: Shipping Crates
well last year my team was a rookie team to so i know how you feel. you could say we made a big out house [no we didnt go to the bathroom in it] but any way the dimensions are 4*4*5 ft 10 in and you can screw in the controller [ the controller was mounted on wood ], i recommend that you put a thicker peace of wood where you screw it in if you use that idea and or use smaller screws also make a little box just big enough to fit the amount of battery's in so they aren't flopping around [on the inside ].I think thats all i can do for you and sorry about the spelling errs I'm not the best speller
Unread 15-02-2006, 20:21
Michelle Celio's Avatar
Michelle Celio Michelle Celio is offline
dream. belive. accomplish.
Michelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond repute
Re: Shipping Crates
Next to the "submit reply" button, there is a "Spell check" it helps, i use it with almost every post, I'm not the best speller.
Last year, this what our crate and robot looked like, I wasn't there I was just given the information.
UCF History & Education '12
Sometimes you just need to step away
"They were shown as everything is shown, for, like the lens of a camera, history is a force that does not discriminate."
JRW <3
Volunteering: IRI - Reset 07/08, Mission Mayhem 07 - Referee
TnT - Referee 07/08, FLL Florida State Tournament - Judge 08/09
Florida Regional 08 - Reset/Repair, Florida Regional 09/10 - Photographer
8 Events - Web Evaluator 08/09/10
Unread 15-02-2006, 20:29
FRC #1888
Re: Shipping Crates
do you need full 2 by 4 inner structure or does the 1/2 inch plywood pretty much hold the box together
Unread 16-02-2006, 02:27
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: Shipping Crates
Be careful when adding shelfs and storage inside the crate. Go overweight, and you'll have some hefty bills to pay drayage and FedEx when you uncrate your bot at the regional.
We use a crate, with a pallet base (and a sheet of plywood over it) then its built up using 2x4s that were ripped in half (2x2s .. well .. 1.5x1.5s) and then plywood over the sides. The thickness of the ply has slipped my mind (which is pathetic since I was putting the crate together tonight), but it seems like it was 1/2".
Inside, we have a small plywood box for the batteries, and then the robot. Over the last 2 years, we've mounted the bots differently (last year we made brackets that physically bolted the robot to the crate; first year we used lag "eye" bolts and ratchet tie downs). One thing to remember, secure any appendages. If you have something that moves (such as an arm), make sure you secure it to the robot or the frame some how. Stuff WILL shift inside the crate. Something else worth mentioning that we have discovered .. the crates aren't kept very dry. Back when FIRST gave us the drill motors, ours rusted in the crate. Steel shafts started to rust/oxidize. This is something to consider when you're thinking about shipping tools. Unless you really want to pay for the extra fees, I would recommend bringing your tools to competition anyways.
With that said, heres our crate (with our 2004 bot)
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 16-02-2006, 03:04
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Shipping Crates
If you go into 'Picture Galleries' at the top of the forum page and than go to the different years listed there is a 'Crate' site. Some of the pictures show the inside of the crates.
We built ours using 1/2" plywood sides and 2x4's.
FYI, you must have it off the ground so a forklift can move it. I think the specs are in the manual.
Hope this helps and good luck on your rookie year.
Don't forget to have FUN
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 16-02-2006, 05:46
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Shipping Crates
We pretty much did the same as most people. But I do believe that you are allowed to take your batteries with you and your controls. You do not have to ship them in the crate. Refer to 6.3.5 of the Manual and you do not have to ship the controls or the batteries.
"Teams must include the robot and may include the two batteries...FIRST will allow you to keep all of your robot controls (Operator Interface, OI power supply, joysticks, etc.) and not ship them with your robot on Tuesday, 2/21/2006..."
Unread 16-02-2006, 08:18
Courtneyb1023's Avatar
Courtneyb1023 Courtneyb1023 is offline
AKA: Courtney
Courtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to behold
Re: Shipping Crates
With the dimensions of our robot being different this year from the other 3 years that we have competed. We had concerns that our robot would be to big for the crate that we have used in the past. However, everyone on the team seems confident that the robot will fit. Has anyone else run into this problem this year or any other year?
Unread 16-02-2006, 08:57
arabsponsor arabsponsor is offline
AKA: Barbara Boyles
FRC #0538 (Dragonslayers)
arabsponsor will become famous soon enough
Smile Re: Shipping Crates
[quote=smarcus88]Hi I am a rookie, I was just interested to see how everyone built their shipping crates,
I tried searching to see if their was a post about this and I have seen MOEmentums paper, so I apologize if I am recreating another thread. but any help from some veteran teams would be great[/QUOTE
We build a new crate each year and use 2x4s and 1/2" plywood. I think this is pretty typical. If you have the ability to carry you batteries with you it will cut down on the likelihood of robot damage during shipping. We are fortunate in that we are close enough to our regional that we can put the robot in the crate by itself and take everything else with us. I believe it was two years ago that a a team at Peachtree opened their crate to a squashed bot and had to rebuild on inspection day. Good luck and have a great rookie year.
Shipping to Nats Veselin Kolev Championship Event 5 04-04-2005 19:42
**FIRST EMAIL**/Important Robot Shipping Verification Process dez250 FIRST E-Mail Blast Archive 0 16-02-2005 13:48
**FIRST EMAIL**/FedEx Airbills and Robot Shipping Information Rich Wong FIRST E-Mail Blast Archive 0 05-02-2005 18:55
Saint Louis Shipping Fiasco Frank(Aflak) General Forum 13 02-03-2004 16:25
Proposed shipping schedule archiver 2000 6 23-06-2002 22:18
