Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Unread 15-02-2006, 16:42
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Question Autonomous Mode
How many times is User_Autonomous_Code called? (Please say only once )
Unread 15-02-2006, 16:48
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Autonomous Mode
Look in main.c. It's called every time that (statusflag.NEW_SPI_DATA) is set and autonomous mode is active (i.e. nominally every 26.2 milliseconds).
Unread 15-02-2006, 17:09
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
Re: Autonomous Mode
Well, actually, if you look in user_routines_fast.c, you will see "while(autonomous_mode)". This means that it will only call User_Autonomous_Code() once, and will keep looping until you disable autonomous.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 15-02-2006, 17:14
kaszeta's Avatar
Re: Autonomous Mode
I stand corrected.
Unread 16-02-2006, 13:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Autonomous Mode
It is possible, however, for the robot to go back into autonomous mode after leaving it. This will never happen in a match, but could if you are using a dongle on the competition port.
Unread 20-02-2006, 11:28
1337pcgamer's Avatar
1337pcgamer 1337pcgamer is offline
Son of Plunder
FRC #1843 (Trobots)
Team Role: Webmaster
1337pcgamer has a spectacular aura about1337pcgamer has a spectacular aura about
Send a message via MSN to 1337pcgamer
Re: Autonomous Mode
What is this "dongle" you speak of?
Unread 20-02-2006, 11:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Autonomous Mode
A dongle is a little switch that connects to your OI's competition port and lets you change between disabled, autonomous and user controlled mode. It's used for testing and is fairly easy to build, however AndyMark also sells one for $30.
http://www.mikesorrenti.com/
Unread 09-01-2007, 15:27
bcieslak
Posts: n/a
Re: Autonomous Mode
Make sure reset counters and flags when you come out of autonomous for any reason. So many false starts last year forced teams to have to run out on the field to reset their robots in order to reset their automonous routines.
BC
Unread 10-01-2007, 10:58
Son of Plunder
FRC #1843 (Trobots)
Re: Autonomous Mode
Alright
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
