Go to Post Math is always fun, especially when it's useful. - Guy Davidson [more]
Unread 15-02-2006, 18:28
tstanis tstanis is offline
tstanis is an unknown quantity at this point
Help! What kind of belt will fit on Denso Window Motor
We need to quickly find a belt and pulley to fit our denso window motor. Does anyone have any specs? part numbers? McMaster has a lot of different ones, but I don't know which to use.
Unread 16-02-2006, 14:44
FRC #0701 (RoboVikes)
Re: Help! What kind of belt will fit on Denso Window Motor
umm... i'm not sure that the denso motor shaft is even for a belt... correct me if i'm wrong please... i would use a shaft coupler onto a shaft and then use any timing belt pulley/belt combo you want (you can key the pulley onto the shaft)
Team 701
Unread 16-02-2006, 14:52
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
You are correct that the motor is not made for a belt. There is a coupler and that is the only way (without machining your own parts) to get a pulley attached to the motor. I am about 90% sure that the coupler is made for a 1/2" shaft with a 1/16 key (measure the motor) and you could even turn down the coupler on a lathe to about 1" in dia. and then put a pulley on it (Shaft would be better and easier). You can use any size belt you want with any size pulley as long as you think it can take the load.
Hope this helps!
Link to motor Specs
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Big cim motor belt kasemodz Technical Discussion 2 27-01-2006 15:12
Belt For Fisher Price Motor X-Zero Motors 10 22-01-2006 15:06
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
DC motor design project Ian Mackenzie Motors 0 29-01-2005 13:30
Valeo window motor Mark Jones Motors 3 06-11-2001 16:47
