Go to Post I'm looking forward to January when things will slow down some! - Foster [more]
Unread 16-02-2006, 15:30
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
pic: Team 384 Presents: Sparky 7
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 16-02-2006, 15:35
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Re: pic: Team 384 Presents: Sparky 7
looks good
how tall is it?
Unread 16-02-2006, 15:37
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
No ground loading?
Sweet looking product, can't wait to see you at VCU (if not saturday's building museum scrimmage).
Crebb's Avatar
AKA: James M.
It's ~57" to the top of the lexan.
Team 384 2003-2015
Unread 16-02-2006, 15:38
enderanjin enderanjin is offline
Bokonist Extradorinaire
FRC #1676 (Pascack Pioneers)
Team Role: Operator
enderanjin is on a distinguished road
Send a message via AIM to enderanjin
How thin is it? On the top it looks like one balls-width and it gets wider with every section. It doesn't look like it fills the dimensions that way at the wheelbase, does it? The pictures is slightly deceptive.
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I'm curious why y'all geared your shooter motor down through the kit transmission and then back up again through sprockets.
--Madison--
...down at the Ozdust!
Unread 16-02-2006, 15:40
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
My guess would be ease in mounting. Also, we can never know exactly what is inside of that box....
Unread 16-02-2006, 15:45
Crebb's Avatar
AKA: James M.
We have a line of balls that fall down in levels. I will post a picture from the front later to give a better example. We used the kit transmission to gear down and then back up because we wanted to use something we already had to power the wheel, so we started playing around with it and ended up using it. It also gives a good way to adjust the tension in the chain.
Team 384 2003-2015
Unread 16-02-2006, 16:10
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Sexy, although I do miss the good ole silver Sparky's myself.
Also, why don't you guys use the flags we made for Sparky 5.0? Much nicer than that one. I guess it's a Turner ego thing any.
Looking great James. I'll have to get down to Richmond sometime to check it out for myself.
Unread 16-02-2006, 16:17
I've been wondering about designs like yours. That wheel must be spinning something like 2,000 rpm, right? How well does the chain work at that speed? I always think of normal chains running at fairly modest RPMs and don't have personal experience with bicycle-style chains running that fast. (Although I know I've had cam chains in cars that would run at 6,000+ RPM, but I assume they were designed for that.) We are using timing belts instead of chains, mostly to save weight up high, but I am curious to see the chain-driven systems.
Good luck in your competition(s).
Unread 16-02-2006, 17:24
A.Lathrop A.Lathrop is offline
AKA: Alan
FRC #0975 (Synergy)
A.Lathrop is on a distinguished road
Send a message via AIM to A.Lathrop Send a message via MSN to A.Lathrop
Smile Re: pic: Team 384 Presents: Sparky 7
Nice design.
Hope to see ya'll at VCU or DC at the scrimmage!
Peace out
Alan
Team 1033
Team 1033: 4 years student
Team 975: First year mentor
Unread 16-02-2006, 18:44
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
So are you guys going to go up the ramp?
Unread 16-02-2006, 18:48
Crebb's Avatar
AKA: James M.
Yes, we can succcessfully get on top of the ramp. It took some extra thought and a lot of second guessing with the 4" wheels, but we can get up on top.
Team 384 2003-2015
Unread 16-02-2006, 18:57
call_me_Angles's Avatar
call_me_Angles call_me_Angles is offline
AKA: angles
FRC #1561 (RoboDucks)
call_me_Angles can only hope to improve
Send a message via MSN to call_me_Angles
friggin awsm
Unread 16-02-2006, 21:46
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Looking great guys, hope we can get paired up again like last year. We'll probably see you at the DC scrimmage again this year. Best of luck this season, can wait till VCU and Nationals!
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Pre-Rookie Teams - The How To Keith Chester General Forum 6 17-09-2008 00:28
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
pic: team 384 CD47-Bot Extra Discussion 5 11-03-2003 19:26
TEAM 384 Sneak Peak ggoldman Robot Showcase 4 09-02-2002 07:32
