Re: I cant get my program into a hex file
I dont use easyc myself but there is likely a button that 'compiles' or 'builds' and that sould do what you want, other than that READ THE MANUAL thats why they spend their time writing it.
Yeah I have hit the compile button... I doesn't spit out a .hex file. It's a file that's specific to easyC. Also I have read the manual and there is no place in it that states how to export to a .hex file.
Make sure the path of your entire project is not too long. I usually just put it under the root directory (C: or w/e drive you use). At the beginning of the season I stuck it in my docs and it wouldnt spit out any hex files either...took a question to a senior programmer before i got it.
I'm not sure if EasyC actually saves the .hex file... but if you click on "Build & Download" or F7 it will actually download the .hex file to the robot for you!
Update: Looks like it saves the .hex file in C:\Program Files\Intelitek\easyC or FRC\FRC\*.hex (just click F7 and than either choose to download right away or later by clicking "Build & Download," and than "Download Window") |
Allright Thanks Guys. We got it now.
Case Closed. |
| C HELP PLEASE | sglegend11 | Programming | 4 | 14-11-2005 21:35 |
| Hex file downloads | Ryan M. | Control System | 2 | 29-10-2005 19:50 |
| hex file garbage? | sciguy125 | Programming | 2 | 04-07-2005 23:04 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Improving PBASIC: Request for Comments | Greg Ross | Programming | 19 | 16-02-2002 22:14 |
