Go to Post There's a stark difference between bragging and taking pride in your work. While "Ha ha! We're better than you! We won seventeen regionals and you didn't!" would clearly fall in the former, listing your achievements would definitely fall in the latter. - artdutra04 [more]
Unread 16-02-2006, 18:48
douglass1371 douglass1371 is offline
FRC #1371
douglass1371 is an unknown quantity at this point
Victors Controlled By Joystick Buttons
*topic
Any help would be greatly appreciated
Unread 16-02-2006, 19:49
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Victors Controlled By Joystick Buttons
if you want the victor to go full forward when the button is held down, then you can do something like:
pwm05 == the pwm channel the victor is connected to
p1_sw_trig == joystick button that activates victor
if (p1_sw_trig)
pwm05 = 254;
else
pwm05 = 127;
The if statement executes faster than a multiply or some other way of mapping.
You may also need to debounce the joystick button, but since you say you are connecting it to a victor and not a pneumatic of some kind it may not matter.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 17-02-2006, 01:57
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
You can also, using Joel's code, change the 254 to something else smaller to change the speed of the item you are looking to control. Just keep in mind 127 is center less than is one direction, more than is the other direction.
ie
if (p1_sw_trig)
pwm05 = 75;
else
pwm05 = 127;
-Mike
Free programming help Cuog Programming 24 24-01-2006 16:43
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
Victors controlled with joystick Buttons JamesBrown Programming 2 18-02-2005 23:39
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
