Go to Post this has Bugs Bunny/Road Runner physics written all over it! - KenWittlief [more]
Unread 16-02-2006, 19:19
Rachika Garcia's Avatar
Rachika Garcia Rachika Garcia is offline
AKA: Brian Armstrong
FRC #0399 (Eagle Robotics)
Rachika Garcia is on a distinguished road
Send a message via MSN to Rachika Garcia
Robot Mishap
We were testing the speed of the balls coming out. And the lawn sprinklers turned on under the robot. What are the possibilities that our chips and victors and stuff were fried?
Thanks,
Brian Armstrong
Product Integration Manager
Team 399 Eagle Robotics
Lancaster, Ca
Unread 16-02-2006, 19:33
Bharat Nain's Avatar
Re: Robot Mishap
It depends. If the water hit the electronics while they were turned ON, the electronics probably fried. Otherwise, you might have a shot but make sure everything is extremely dry before you try anything.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 16-02-2006, 19:44
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Robot Mishap
Did the robot stop operating? Did any breakers "pop"? Is there water dripping out of the motors?
These are some clues that you might have some real issues. If the motors got really soaked, it may take quite a while for them to dry out. You might want to disconnect the motors on the robot and see if the rest of the electronics components (RC, Victors, radio) turn-on properly (after they've been allowed to dry). Then you can checkout your motors one-by-one.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 16-02-2006, 20:06
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Robot Mishap
You may want to try drying the pieces off using a hairdryer or very, very carefully with a heat gun. Only once you're absolutely sure everything is dry should you try turning parts on again. I might even try to just incrementally reconnect the electronics. Start with just the non-drivetrain parts and then slowly reconnect power to the pieces. Electronics can get wet, sometimes even short and survive but FIRST robot parts, especially victors are prone to dying from relatively simple shorts.
Team Website
Unread 16-02-2006, 21:54
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Robot Mishap
You could also use compressed air to dry things out.
If the water got inside the vents of the motors it could have diluted the lubrication and/or cause rusting. This may not appear as a problem right away, rather become a long term dependability issue. After they dry out listen to them and see how they sound.
The "good" news is atleast this wasn't salt water.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 16-02-2006, 22:09
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Robot Mishap
After hearing the story that dave lavery told about FIRST robots at a demo operating in like 1" of water and rain id say youll be fine, let everything dry out, oil your gears, sprockets and such to prevent rust and cross your fingers.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 16-02-2006, 23:08
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Robot Mishap
Make sure you pull out all the PWM cables, and get the water out from between them..
Take the fans off the victors, blow out whats below them with compressed air.
I can tell you that there's a pretty good chance the robot controller survived. It's one rugged piece of hardware.. I can't even count the number of times we've shorted various pins with metal shavings, to no ill effect. Same with the radio.. we put a pop rivet through the transmit light, and it still worked. Not perfectly, but it worked.
Not knowing what your robot looks like, and what got hit.. I can't tell you much.. make sure you open the transmissions and re-lube them though.. they are the last place you want rust.
Unread 16-02-2006, 23:33
Re: Robot Mishap
Rachika,
The things I am most concerned about would be the speed controllers and the RC. A little water won't kill a motor but it might wash a little of the lubricant out of the bearings. The RC has a pretty tight cover but it is not waterproof. Much of the interior on both the RC and the speed contollers has a coating on the components so they should be good if you are sure they are dry. (The speed controllers are wide open to water and metal shavings. A good shake on a speed controller, (outside of the robot, please) should reveal any residual moisture in side. A hair dryer applied to the opening for several minutes ought to take care of what might be left inside. Dry all electrical connections and let the robot sit for a few hours and you should have very few if any problems.
Sensors, pots, microswitches etc., might not fair as well but use the same technique, shake, inspect and use the dryer. Servos would give the least amount of problems, I think. The wire entry has a gasket and the case is pretty tight so I don't think you should have any problems there.
Robot songs Alex Burman Chit-Chat 19 24-01-2006 08:07
[moderated]: Worst Call Ever and Congratulations from San Jose ducttapejason General Forum 45 12-05-2005 13:23
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
