Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 16-02-2006, 22:00
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Got Weight?
(starts talking in infomercial guy's voice) Is you robot overweight, does your team think that they just wasted 6 hard weeks of work. No worries Ill have the perfect solution as soon as i think of one. please help me with any ideas
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 16-02-2006, 22:03
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Got Weight?
Step 1: Get Drill
Step 2: Insert 1/2"-1" bit into drill
Step 3: Drill Those Speed Holes!
Unread 16-02-2006, 22:46
Clam's Avatar
Clam Clam is offline
Clam Chowder
FRC #1190 (Anonobots-1190)
Team Role: Webmaster
Clam is an unknown quantity at this point
Re: Got Weight?
remove unecessary components that would be cool, but would add weight.
use lighter material (ie: aluminum)...
see news updates...
www.anonobots-1190.com
Unread 16-02-2006, 22:47
tammuoisau's Avatar
tammuoisau tammuoisau is offline
Team Role: Problem Solver
AKA: AKA Thanh
#1648 (GearBox Gangstaz)
tammuoisau is an unknown quantity at this point
Send a message via AIM to tammuoisau
Re: Got Weight?
LIGHTNING HOLES, that's a hint
Team 1648 Grady Gearbox Gangstaz
2005/Fall
South's Best State - 6th in Competition (Regional Qualifier)
Best Regional - 2nd in Competition
Best Regional - 2nd in Elegant
Best Regional - 3rd T-Shirt Design
2005/Winter/Spring
Peachtree Regional - Rookie All-Star Award (National Qualifier)
Peachtree Regional - Finalists (832, 1102!)
National Championships - Galileo - Quarter-Finalists
Unread 16-02-2006, 22:55
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Cool Re: Got Weight?
Make enough holes so you can use your robot as a CHEESE GRATER at the end of the season!
Tomasz Bania
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 16-02-2006, 22:59
pwilczynski's Avatar
pwilczynski pwilczynski is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1993
pwilczynski is on a distinguished road
Re: Got Weight?
if you're using a shooter with two wheels, you could try cutting out some of the spokes and putting some cardboard over it so that it would be just as aerodynamic but weigh less.
Unread 16-02-2006, 23:01
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Got Weight?
Holes help. I think in the past 3 days my team has taken 6-7 pounds off of our robot. Get a couple drills ready, they do heat up when run for a long time.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Re: Got Weight?
Take the white space out of your program.
Unread 16-02-2006, 23:32
Billfred's Avatar
Billfred Billfred is offline
Re: Got Weight?
Ha.
But getting back to the speed holes, I'll put in the boilerplate: don't be stupid with the swiss cheesing. Poking a bunch of holes in your hopper that was built around the requirement of having a perfectly smooth bottom may come back to bite you in your bottom.
Just be smart about where you poke holes, and you'll be good.
Unread 16-02-2006, 23:33
adam adam is offline
FRC #1717 (DP Engineering)
adam is an unknown quantity at this point
Send a message via AIM to adam
Re: Got Weight?
good idea
Unread 16-02-2006, 23:46
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Re: Got Weight?
Switch the air in your tires with helium.
Unread 17-02-2006, 00:35
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Got Weight?
drill one-way holes in your air cylinders.
Then refill your brake light fluid.
And change your muffler bearings.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 17-02-2006, 00:49
Re: Got Weight?
Don't forget to remove all the comments in your code, and scrape the insulation off all the wiring.
Unread 17-02-2006, 00:55
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Got Weight?
And drill holes in the RC, radio, and camera.
Seriously, though, it looks like we will be underweight...by 2 pounds!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 17-02-2006, 01:00
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Re: Got Weight?
Use a smaller font in the code.
Also, avoid using entire colons when a semicolon would work just fine.
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
