Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 17-02-2006, 08:07
edman edman is offline
edman is an unknown quantity at this point
Cool Programming the parallax PING))) Ultrasonic Sensor
Hi,
Has anyone programmed the parallax ultrasonic range finder to work with the Full-size FRC? If so could you kindly show me how to do that? I have already seen the sonar.c and sonar.h code written by Mike but it is for the EDU and he told me that he has not tested it on the Full-size RC yet. If anyone has, could you kindly show me how?
Unread 17-02-2006, 08:28
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: Programming the parallax PING))) Ultrasonic Sensor
Originally Posted by edman
Hi,
I have tested it on the full sized RC and it works well with no changes. I tried to rewrite the sonar driver to use only one digital IO pin but the pin cannot be changed quickly from output to input.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 17-02-2006, 09:42
Cool Re: Programming the parallax PING))) Ultrasonic Sensor
I have also tested it on the full RC but it does not build because it try to find the <pecdef.h> header file from Kevin's code. When I downloaded Kevin's code, I got an error message after including the sonar.c and sonar.h in the project. the message was making ref. to PIC18f8520 which is the microcontroller on the mini-rc. Can you tell me how you got it to work?
Unread 18-02-2006, 23:37
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Take a look at this post.
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
