Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
Unread 17-02-2006, 11:50
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
timers in user_routines_fast
hi, I'm trying to create a generic timer in user_routines_fast. I don't need any exact amount of time to be calculated, just about 2/3 of a second. the code I'm using basically acts like this:
static int counter = 0;
if (counter >= 20)
//now I'm at where I want to get after 20 program loops
counter = 0;
else
counter++;
but I'm not having any luck in the fast file. what am I doing wrong? I have no problems in user_routines, but in fast everything doesn't work timer-wise. any ideas or help? thanks.
Stephen
Unread 17-02-2006, 12:02
Electrical Engineer
Rookie Year: 1995
Re: timers in user_routines_fast
Stephan,
In user routines, you are counting loops timed by the master uP communicating with the OI. Each loop takes about 26 milliseconds so your counter should take about a half second to "trip".
In user routines fast, there is no such delay and the loop is timing as fast as it can, With a 40 MHz clock (and ignoring other code which you may have in the fast loop) your timer will "trip" in about 1 microsecond (maybe less).
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 17-02-2006, 12:35
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
It's highly recommended to use one of the hardware timers instead of counting loops. There's been extensive discussion on these guys and they aren't very difficult to use - you'll love them!
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
The Five Great Timers CronosPrime1 Programming 2 12-02-2006 12:46
Using Timers psquared Programming 9 30-01-2006 10:29
Timers MarkVH Programming 1 13-02-2005 11:30
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
How do you program timers? roberthan Programming 5 04-02-2004 02:18
