Go to Post ...and part of being Graciously Professional is knowing what your job is and how to perform the duties of it accurately. - jamie_1930 [more]
Unread 17-02-2006, 12:29
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Re: Gear Tooth Sensor FIRE
Originally Posted by Aaron_H
Greetings,
This past friday, our robot caught on fire in a catastrophic failure of the gear tooth sensor. The way we hooked it up is as follows (I know its wrong):
PWM cable from the J1 (12 v and G) solder connections on the sensor to digital input 1..
No connection to the breaker panel.
This configuration caused the wire to heat up so that it combusted. Today, with the remaining gear tooth sensor, after realizing it was originally connected in the wrong fashion, we connected J1 Black to Ground and White to the Positive side of the breaker. We connected J2 Black, Red, and White, respectively, to digital input 3. This caused one of the speed controllers for our drive motors to trip the breaker panel. Somewhere in the process, the pwm cable going to the robot controller heated up again and melted, but did not ignite since we caught the problem earlier. Does anyone have any clue as to what might be wrong? Also, the wire that melts is always the ground wire...
Thanks in advance
Aaron;
this has been probably noted else where and before but here goes. Make sure that you do not have a positive side short to your chassis. This can be very subtle and not always obvious. During the 2003 build our team discovered this problem when the RS 232 cable from the tether port to the OI flamed. The short was discovered at the 120amp breaker as the positive battery side cable was shorted directly to the breaker mounting bolt next to it. The on-board electrical circuits were otherwise isolated from ground so the only time the heating occurred was when the robot was connected to an external ground via the RS 232 cable. We did not sustain any on robot damage from this but learned a good lesson anyway. LRU.
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Will the gear tooth break? sanddrag Technical Discussion 11 23-01-2006 14:24
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
