Go to Post How are you planning to teleport balls? Or your robot? I was pretty sure that the battery couldn't supply the required power draw. - RoboChair [more]
Unread 17-02-2006, 01:02
Re: Got Weight?
Originally Posted by Chriszuma
Use a smaller font in the code.
C'mon now, thats just silly.
Everyone knows the weight of code is really influenced by how many non working sections you have commented out!
Unread 17-02-2006, 01:28
InnocentBlond's Avatar
InnocentBlond InnocentBlond is offline
AKA: Sabrina
FRC #1266 (The DEVIL DUCKIES!)
Team Role: Driver
InnocentBlond is an unknown quantity at this point
Re: Got Weight?
Originally Posted by Henry_222
Holes help. I think in the past 3 days my team has taken 6-7 pounds off of our robot. Get a couple drills ready, they do heat up when run for a long time.
Robot liposuction
Also try trimming bolts that are at unnecessary lengths, it adds up
Unread 17-02-2006, 07:49
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Got Weight?
Remove three strands from every wire.
But seriously copper is heavy shorten any excess wire runs and service loops.
Also swissing your robot isn't really good for that much weight. You can only get a couple pounds usually.
Thinner lexan and narrower diameter pneumatics are also good tricks if you can.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 17-02-2006, 09:09
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Re: Got Weight?
You'd be surprised with the speed holes. Last year we removed almost 20 pounds from ours, granted we had an 18' telescoping boom made of 1/8 aluminum box tubing, but still, it adds up, every little bit counts. And the thinner lexan is a good point, thinner everything will work really, we cut alot of weight a few years ago by going down 1 size in all the PVC tubing we used.
Also, smaller/less motors if you can, they weigh a bit.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 17-02-2006, 09:24
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Thumbs up Re: Got Weight?
Originally Posted by Billfred
I'll put in the boilerplate: don't be stupid with the swiss cheesing. Poking a bunch of holes in your hopper that was built around the requirement of having a perfectly smooth bottom may come back to bite you in your bottom.
Just be smart about where you poke holes, and you'll be good.
I'll post a picture soon of our robot, and you will see that the back of our robot (specifically the ball catcher, not the hopper) literally looks like a cheese grater!
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 17-02-2006, 09:35
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
Re: Got Weight?
I was told that we're calling in the Orkin Man to debug our code for us - that should take a good deal of weight out.
You'd be surprised what you can put holes in that willl actually benefit your robot's functionality. I can't comment on speed effects really, but in terms of moving balls around...
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 17-02-2006, 09:36
Re: Got Weight?
There's your problem right there. We only got .2 lbs when we lightened out arm last year, however ours was only 13 feet.
Thank-you 294 & 67
Unread 17-02-2006, 10:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Got Weight?
You could replace heavy steel sprockets with lightweight aluminum ones.
That might save a few pounds.
Unread 17-02-2006, 13:28
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Got Weight?
Ha.
But getting back to the speed holes, I'll put in the boilerplate: don't be stupid with the swiss cheesing. Poking a bunch of holes in your hopper that was built around the requirement of having a perfectly smooth bottom may come back to bite you in your bottom.
lol...
holes work no matter where you put them.. As long as it isnt in a major compenent ...lol
-Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 17-02-2006, 13:41
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Re: Got Weight?
We weighed in this morning at the local fruit packing plant. It was 114 lbs. Our robot is having surgery as we speak. 114 was too much as we still have things like shields and bracing to install, battery covers, and part of the hopper. Took off 5 lbs by removing a noncritical part and replacing it with something lighter. WOWOWOW. Diet time.
Last years robot was 4 ounces under the 120 limit.
Carolyn Hinckley
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 17-02-2006, 13:52
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Got Weight?
Last year I ordered aluminum nuts and bolts for my team. Bolts, nuts and washers are made of steel which is much heavier than aluminum(about 5x as much). Most bolts and nuts also don't take even close to the load necessary to break or bend them. We didn't build our robot with them, but I took an inventory of the major bolt sizes we used and brought boxes of aluminum replacements to the competitions. Whenever we needed to change a part we optimized it with aluminum parts.
I've also heard of team using plastic hardware which is 1/3 the weight of aluminum and I guess 1/15th the weight of steel.
Team Website
Unread 17-02-2006, 14:49
Zach Purser's Avatar
Zach Purser Zach Purser is offline
AKA: Gumby
FRC #0435 (Robodogs)
Zach Purser is a jewel in the roughZach Purser is a jewel in the roughZach Purser is a jewel in the rough
Send a message via AIM to Zach Purser
Re: Got Weight?
Compressor:
Last year we made a backpack with a compressor and a battery so we could fill the tanks right before each match. It saved us a few pounds.
Structure:
Re-evaluate your structural design. Chances are you have over-engineered some parts. Can they be replaced with thinner materials?
Durable vs. disposable:
Can you replace something that is very durable with something that will last you through a match and can then be replaced? Our team uses 1/16" polycarbonate for shielding our robot. Some pieces survive an entire regional unscathed, other pieces need to be replaced every couple rounds. We could have used thicker polycarb and spent less time replacing stuff, but we get a lot more functionality by having a few extra pounds to work with. Of course, if you go the disposable route, be sure it's easy to replace and you have lots of spares.
Dave Lavery uses search before he posts, and you should too.
Unread 17-02-2006, 15:31
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: Got Weight?
While our robot is made of holes, it is important to remember that you need about 40 1" holes in 1/4" Al to cut out a pound of weight.
So get drilling.
Unread 18-02-2006, 19:00
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
Re: Got Weight?
Get on your hands and knees with a file.
Unread 18-02-2006, 21:17
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
Re: Got Weight?
Advice to stay underweight:
Use ligher materials whenever possible, but use metal for things that have to be more robust, such as turrets, drive, and moving parts.
Use PVC for nonmoving parts, such as bins.
Weigh the parts of your robot, and your robot at each substage of building.
Don't use pneumatics.
Budget your weight and keep to your weight budget.
Remember, design each part with weight in mind. A well-designed, well-built robot should not have to deal with a weight problem.
Advice to get underweight if overwieght:
Make Swiss cheese (something that's already been said way too much)
Don't use more motors than you need.
Keep your frame simple.
Look for lighter alternatives to what you have. This invovles doing a bunch of research.
Remove unnecessary parts
POWERHAWKS FORUM
2006 Chesapeake Regional Semifinalists (Thank you 614 and 339!)
UM Class of 2010!!
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
