Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 13-02-2006, 23:40
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: What is T_Packet_Data.my ??
Originally Posted by 354.FIRST
Is this what we should be using to know if our camera has a target in sight and centered?
No. Looking at mx, my, or even confidence does not mean the target is centered. Mx and my are undocumented but they are the target centroid in pixels in the sensor grid of IMAGE_WIDTH pixels by IMAGE_HEIGHT pixels which Mike reported. The tracking code which has modes of searching, tracking, and locked is separate. But the default tracking code does not make these modes available for use elseswhere. I modified our tracking code to make these available.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 14-02-2006, 00:14
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by Mike
I don't think he is saying that it sends a t-packet with a non-zero value for .my/.mx but rather that the .my/.mx that is already stored does not change it's value when the image of a blob is lost.
This isn't possible. The .mx value is only tested when the camera has sent a new t-packet. From what Greg and Keith are saying, it seems as though the camera does spit-out funky t-packets under weird lighting conditions.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2006, 14:45
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally Posted by Kevin Watson
Greg, are you saying that the CMUcam2 will occasionally send a t-packet with a non-zero value for .my when it does *not* have a tracking solution?
Correct. I believe I saw non-zero "my"s with very low confidence (possibly as low as 0.)
BTW, did Rob Steele know about this?
I'm not sure if Rob was around when I made the discovery.
What Keith reported corresponds very closely to my experience, although I didn't attempt controlled experiments. I just noticed that sometimes the camera locked on to a spot well away from the target, and noted that the confidence was zero (or so.)
Unread 14-02-2006, 14:58
FRC #2429
Okay, I'll update the code to use the .confidence value as a discriminator instead of .my. Thanks for the information.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-02-2006, 23:11
FRC #2429
Originally Posted by Keith Watson
After reading what Greg found in the other thread, Saturday our programmer changed the terminal routine to dump out mx, my, and confidence and we ran tests. We saw non-zero mx, my values with confidence up to 6 or so with the target outside the camera's field of view. When the target is in the field of view the confidence was as low as 140 but was mostly well over 200.
I'm altering the tracking code to use the t-packet confidence value as a discriminator. Do you have a better idea of what the default value should be for the code?
-Kevin
Kevin Watson
http://kevin.org
Unread 16-02-2006, 00:42
FRC #0957 (WATSON)
-Kevin
When we saw values down to 140 with the green light that was with the target light tilted more than 45 degrees away and objects possibly partially blocking the light. But I consider 140 valid. With white lights we saw a maximum of 6. I would consider up to 10 invalid. That leaves a pretty large unknown range. Our programmer chose a level of 100. I think it was Greg who mentioned using 80 or 90.
Unread 16-02-2006, 01:25
FRC #2429
Keith,
Can you do me a favor? Can you grab this code and test it under the conditions that caused the camera to send the low confidence t-packets? These are the changes I've made so far:
1) All changes to servo position are now done through two functions, which will make it easier for teams to use the CMUcam2 servo outputs if they desire.
2) Fixed bug in search initialization code where temp_pan_servo was initialized to zero instead of Tracking_Config_Data.Pan_Min_PWM.
3) Altered tracking algorithm to use the t-packet confidence value to determine whether the code should track or search. This value can also the changed on-the-fly from the tracking menu.
4) Added Get_Tracking_State() function, which can be used to determine if the camera is on target. New code in Process_Data_From_Master_uP( ) uses this function to turn on the switch3 LED on the operator interface when the camera is on target.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-02-2006, 13:47
FRC #0957 (WATSON)
Kevin,
I have arranged to get some camera time to test your changes. It will be on Saturday morning before the bot goes to a scrimmage. It will be Saturday evening before I can report back.
Keith
Unread 17-02-2006, 11:38
kevlarman kevlarman is offline
"why cant i install Linux?" guy
AKA: Roman Tetelman
None #0100
kevlarman is an unknown quantity at this point
The non-zero my's probably come from stray pixels that the camera finds (like if the room is lit w/ flourescent lights and there is green or yellow paper on the walls), this doesn't make much of a difference most of the time, but it's annoying that it resets the search pattern, which results in the camera getting stuck going in circles and never finding the target (in our debugging we have gotten around this by covering its field of view until it was facing the target, we should probably make it not reset the search pattern ourselves, but hasn't annoyed us enough to do so yet)
EDIT:
i would also try changing
if(new_search == 1)
in tracking.c to:
if(FALSE)
(or if you aren't as lazy as I am just get rid of the whole if block and remove the else)
EDIT 2:
it's also be possible to not set new_search to 1 until after ~.5 seconds of seeing the target, since it will usually lose the stray pixels by then, but I don't see the benefit of reseting the search pattern.
Unread 17-02-2006, 13:23
FRC #0957 (WATSON)
If the logic for tracking vs searching is changed from "is there a target pixel" to "is there confidence" then this problem goes away. For some reason confidence is only large if there is a green light.
Unread 17-02-2006, 13:30
AKA: Roman Tetelman
None #0100
the confidence can drop sharply if there is a reflection of the target somewhere (which is likely considering all the reflective surfaces on the field), so finding that value that won't pick up the reflections but will pick up the real thing may be difficult.
Unread 19-02-2006, 15:14
FRC #0957 (WATSON)
Kevin,
Keith
Kevin,
I have sent email with feedback. It looks good. The feedback is just a couple of minor things in the comments.
Keith
