Go to Post It's still not about the robots. FIRST is about doing the right thing. - DonRotolo [more]
Unread 17-02-2006, 14:07
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: The silly syntax errors that won't go away!
Originally Posted by xrabohrok
Alrighty. I am pretty new to C, though not that new, and I have decided to attempt to try making my own libraries and attached .c files to see how they work. Through much thinking, I have decided to make a program that would simulate a blackjack deck. What I have here isn't very flexible, and it just draws five cards. But when I compile, it says everything in the .h file has been declared twice! I don't know what to do! Here's the code:
main.c
deck.c
deck.h
the board didn't keep any of the formatting. Sorry!
This is a common problem. Your variables are being declared in every file that includes them. So use it more than once....it defines them in multiple files.
In the file that needs to own them, in this case deck.c, flank the include statement with
#define VAR_DECLARE
the include
#undef VAR_DECLARE
Then in your header file, wrap all the code declaring the variables in
#ifdef VAR_DECLARE
code goes here
#else
extern code goes here
#endif
After the else copy your code defining the variables, but put extern in front of each, that means to the compiler "This is already declared elsewhere, use that version."
Example:
C file that owns header:
#define VAR_DECLARE
  #include "header.h"
#undef VAR_DECLARE
C file that uses header, but does not own it:
#include "header.h"
Header file:
#ifdef VAR_DECLARE
  char myChar1;
  int myInt1;
#else
  extern char myChar1;
  extern int myInt1;
#endif
Matt Krass
Unread 18-02-2006, 11:11
kevlarman kevlarman is offline
"why cant i install Linux?" guy
AKA: Roman Tetelman
None #0100
kevlarman is an unknown quantity at this point
actually the more traditional way to do that is
#ifndef _MY_HEADER_FILE_H_
#define _MY_HEADER_FILE_H_
//other stuff in the header goes here
#endif
and make sure that all variables are declared extern (and initialized in the .c file that owns them), otherwise each file will get its own copy of the variable.
EDIT:
forgot to mention that _MY_HEADER_FILE_H_ should be the name of the file it is in (in this case it would be myheaderfile.h), if two files have the same #define at the top, one will get ignored
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Union Errors in AutoCAD indieFan Inventor 4 16-07-2004 12:54
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Specs full of errors??? Simon G Motors 1 20-01-2003 12:53
